Generator
10-14-2008, 12:38
Post: #21
Generator
Richard here, quit upday on my yanmar 12.5Kvw. Still looking for bad
wire#5, that comes out of the top of the starter solenoid, know that it is in the wires that go behind the motor then connects with a big set of wires that come down an out on the left side, go back around the back of the gen. set, thinking them wires go to the right side the controller wires are their, an the harness of wires from the controller. I have a dead wire 0n #5, have jumper that wire to the 5 terminal in the controller, lets me start the gen, an runs great. Asking if I'm on the right track here? |
04-03-2010, 23:04
Post: #22
Generator
My generator will not move when I press the in and out Bill 83 PT 35’wanderlodge 92TDD silver PCFL |
04-04-2010, 04:02
Post: #23
Generator
Have you checked the level of the hydraulic tank under your steps?
That's why mine wouldn't move. Art Weatherly Riverside Ca '85 PT36 --- In WanderlodgeForum@yahoogroups.com, "Bill Jowers" <bgjowers@...> wrote: > > My generator will not move when I press the in and out button. We can Hear > the motor running but nothing happens. I assume there is a gear or shaft > that is the problem. > > > > Bill > > 83 PT 35'wanderlodge 92TDD silver > > PCFL > |
04-04-2010, 05:09
Post: #24
Generator
The genset tray on the 83PT moves in and out courtesy of a hydraulic ram
cylinder. It operates off the same hydraulic motor and oil supply (under the front entry steps) as the leveling jacks. If the hydraulic motor is running, as you state, then you are either low on oil (as Art stated) or there is a seal leak on the cylinder. If you are low on hydraulic fluid, the leveling jacks should not operate properly either. Is there a puddle of hydraulic oil under the genset tray? If so, let us know and I'll post how to repair the hydraulic ram cylinder seals. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Bill Jowers" <bgjowers@...> wrote: > > My generator will not move when I press the in and out button. We can Hear > the motor running but nothing happens. I assume there is a gear or shaft > that is the problem. > > > > Bill > > 83 PT 35'wanderlodge 92TDD silver > > PCFL > |
04-04-2010, 05:14
Post: #25
Generator
BTW, BB recommended Dexron ATF in the hydraulic system for that year. Check to
make sure the existing fluid looks red like ATF. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > The genset tray on the 83PT moves in and out courtesy of a hydraulic ram cylinder. It operates off the same hydraulic motor and oil supply (under the front entry steps) as the leveling jacks. If the hydraulic motor is running, as you state, then you are either low on oil (as Art stated) or there is a seal leak on the cylinder. If you are low on hydraulic fluid, the leveling jacks should not operate properly either. Is there a puddle of hydraulic oil under the genset tray? If so, let us know and I'll post how to repair the hydraulic ram cylinder seals. > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > > > --- In WanderlodgeForum@yahoogroups.com, "Bill Jowers" <bgjowers@> wrote: > > > > My generator will not move when I press the in and out button. We can Hear > > the motor running but nothing happens. I assume there is a gear or shaft > > that is the problem. > > > > > > > > Bill > > > > 83 PT 35'wanderlodge 92TDD silver > > > > PCFL > > > |
04-04-2010, 05:21
Post: #26
Generator
04-04-2010, 06:13
Post: #27
Generator
Mike,
I'd like the directions for an 85 PT40. Mine seems to be leaking and I haven't had the time to tackle it yet. But, I need to get my bottom in gear and get it fixed. I appreciate the help.
Jerry
85 PT40
From: mbulriss <mbulriss@...> To: WanderlodgeForum@yahoogroups.com Sent: Sun, April 4, 2010 10:09:58 AM Subject: [WanderlodgeForum] Re: Generator The genset tray on the 83PT moves in and out courtesy of a hydraulic ram cylinder. It operates off the same hydraulic motor and oil supply (under the front entry steps) as the leveling jacks. If the hydraulic motor is running, as you state, then you are either low on oil (as Art stated) or there is a seal leak on the cylinder. If you are low on hydraulic fluid, the leveling jacks should not operate properly either. Is there a puddle of hydraulic oil under the genset tray? If so, let us know and I'll post how to repair the hydraulic ram cylinder seals. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In "WanderlodgeForum%40yahoogroups.com", "Bill Jowers" <bgjowers@.. .> wrote: > > My generator will not move when I press the in and out button. We can Hear > the motor running but nothing happens. I assume there is a gear or shaft > that is the problem. > > > > Bill > > 83 PT 35'wanderlodge 92TDD silver > > PCFL > |
