Fwd: Re: Street-side slobber tube leaking oil and coolant
05-04-2009, 09:49
--- In DetroitDiesel@yahoogroups.com, "evansengine" wrote:
--- In DetroitDiesel@yahoogroups.com, "trudylundgren" wrote:
> Coolant out the air box drain tube would probably be leaking liner o-rings.
The 92 series is a wet liner engine and there are 2 o-rings just above the air
box area to seal in the coolant around the top of the liner. Usually fail due to
overheat.
--- End forwarded message ---
05-04-2009, 09:52
Is there anyone in the Vegas area that can help Lisa with this??
83PT40
Wanderlodge
--- On Mon, 5/4/09, Ernest Ekberg wrote:
Subject: [WanderlodgeForum] Fwd: Re: Street-side slobber tube leaking oil and coolant
To: wanderlodgeforum@yahoogroups.com, diesel-rvs@yahoogroups.com
Date: Monday, May 4, 2009, 4:49 PM
--- In "DetroitDiesel%40yahoogroups.com", "evansengine" wrote:
--- In "DetroitDiesel%40yahoogroups.com", "trudylundgren" wrote:
> Coolant out the air box drain tube would probably be leaking liner o-rings. The 92 series is a wet liner engine and there are 2 o-rings just above the air box area to seal in the coolant around the top of the liner. Usually fail due to overheat.
