					Looking for parts of my '79
					04-09-2009, 07:52
					Hello All,
			I've got a '79 FC-33 w/ Cat 3208 NA. I'm looking for new motor mounts and replacement LED tail and marker lights. Anyone have any sources and/or part numbers? Any help would be greatly appreciated. Thanks, Lin  |
					04-09-2009, 11:14
					Lin - I got rear mounts from Bluebird a while back.  Because this is a chassis
			part also used in school busses, it is likely they can still supply them. BB could not supply front mounts. I've found a mount that should work but have not tried them yet. If I pull of a successful front mount swap I will post the details. Changing the rear mounts made a big difference in noise and vibration. Bob Griesel '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, "lin_borkey" > > Hello All, > > I've got a '79 FC-33 w/ Cat 3208 NA. I'm looking for new motor mounts and replacement LED tail and marker lights. Anyone have any sources and/or part numbers? Any help would be greatly appreciated. > > Thanks, > Lin >  |
					04-10-2009, 06:07
					Lin,
			If you can look at your mounts, they should be a round donut type mount. It's a pretty standard mount, from what I've learned, so any decent truck parts house should be able to fix you up. You may also be able to find your lights there as well. They do have a bunch of light style available. Good Luck John --- In WanderlodgeForum@yahoogroups.com, "freewill2008" > > Lin - I got rear mounts from Bluebird a while back. Because this is a chassis part also used in school busses, it is likely they can still supply them. > > BB could not supply front mounts. I've found a mount that should work but have not tried them yet. If I pull of a successful front mount swap I will post the details. > > Changing the rear mounts made a big difference in noise and vibration. > > Bob Griesel '84 FC31 WLII WA > > --- In WanderlodgeForum@yahoogroups.com, "lin_borkey" > > > > Hello All, > > > > I've got a '79 FC-33 w/ Cat 3208 NA. I'm looking for new motor mounts and replacement LED tail and marker lights. Anyone have any sources and/or part numbers? Any help would be greatly appreciated. > > > > Thanks, > > Lin > > >  |
