Dump Valves
04-18-2005, 07:40
Dump Valves
I un-winterized my new (to me) Wanderlodge yesterday. When I went to
dump the holding tanks, the black water valve opened easily, but it took me 20 minutes of yanking and kicking to get the grey valve open. Once open I repeatedly opened and closed it about 10 times hoping to loosen it up. About an hour later I tried to open it again and was able to get it open, but it was still very stiff. Is there anything that works to lubricate these valves? I don't want to have to struggle with these each time, but I also would prefer not to replace them. Phil Olson '83 FC35SB Appleton, WI |
04-18-2005, 07:51
Dump Valves
Phil,
Contact Randy Dupree, 800-585-3140, he made the valves and has the knowledge to either sell you the right parts or tell you how to fix them yourself. Good guy who won't lead you astray. Chet Geist 1981 FC33, Austin, Texas -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of olson_phil Sent: Monday, April 18, 2005 2:41 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Dump Valves I un-winterized my new (to me) Wanderlodge yesterday. When I went to dump the holding tanks, the black water valve opened easily, but it took me 20 minutes of yanking and kicking to get the grey valve open. Once open I repeatedly opened and closed it about 10 times hoping to loosen it up. About an hour later I tried to open it again and was able to get it open, but it was still very stiff. Is there anything that works to lubricate these valves? I don't want to have to struggle with these each time, but I also would prefer not to replace them. Phil Olson '83 FC35SB Appleton, WI ---------------------------------------------------------------------------- -- Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-08-2005, 04:26
Dump Valves
Hi All,
I need to remove the tubes to the valves to test the operation of the dump switch. They are attached with a unique fitting. Well, it's unique to me. I see a white ring at the connection point. How do I take these tubes off so I don't wreck them so I can put them back on? Thanks, Craig 91PT40 WPB, FL P.S. I have ordered a couple of new shocks for the front. I took off one side and when I pushed it in to adjust the tension, it pushed in so easy I decided to get new ones. No wonder the front had a bounce to it. |
06-08-2005, 04:30
Dump Valves
They are quick-connect, you push the collar down the plastic tube
toward the fitting and the tubing should slide out. Be sure there is no burr and that the tubing is pushed straight back in or you could damage the O-ring inside the quick-connect fitting. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "casmith" > Hi All, > I need to remove the tubes to the valves to test the operation of the > dump switch. They are attached with a unique fitting. Well, it's > unique to me. I see a white ring at the connection point. How do I > take these tubes off so I don't wreck them so I can put them back on? > Thanks, Craig 91PT40 WPB, FL > > P.S. I have ordered a couple of new shocks for the front. I took off > one side and when I pushed it in to adjust the tension, it pushed in > so easy I decided to get new ones. No wonder the front had a bounce to it. |
06-08-2005, 06:30
Dump Valves
you push the white thing towards the cyl,while pulling the air line away for the
cyl..you need to do this with no air pressure on the line. randydupree93wb ----- Original Message ----- From: casmith To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, June 08, 2005 12:26 PM Subject: [WanderlodgeForum] Dump valves Hi All, I need to remove the tubes to the valves to test the operation of the dump switch. They are attached with a unique fitting. Well, it's unique to me. I see a white ring at the connection point. How do I take these tubes off so I don't wreck them so I can put them back on? Thanks, Craig 91PT40 WPB, FL P.S. I have ordered a couple of new shocks for the front. I took off one side and when I pushed it in to adjust the tension, it pushed in so easy I decided to get new ones. No wonder the front had a bounce to it. ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
