Bus Standing TALL
08-25-2008, 05:54
Bus Standing TALL
After airing up the suspension (air springs), the front and the rear of the coach height is about 2" taller than normal. Suspension was cycled three times and no change. I doubt the 3 ride-height valves would go bad at the same time. Thoughts?
Curt Sprenger
Anaheim Hills, CA
08-25-2008, 06:11
Bus Standing TALL
It is just taller ??? This is odd ???
If the coach is still level,
I would suggest, that Curt is shorter, ( shrinking)??
Bill 88 FC Michigan
--- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger"
rear of the
three
at the
> Curt Sprenger
> Anaheim Hills, CA
08-25-2008, 06:24
Bus Standing TALL
Curt: I had that happen just on the front one time. Actually, one side was a bit higher than the other. I drove it around the block and it settled down. I do not know why.?? It has not done it again.
I cannot see that it will hurt anything to try.
But like GregO says, it ain't the effect or symptom, it's what created it..
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
Royale Conversion
--- On Mon, 8/25/08, Curt Sprenger wrote:
Subject: [WanderlodgeForum] Bus Standing TALL
To: "WanderlodgeForum"
Date: Monday, August 25, 2008, 1:54 PM
Curt Sprenger
Anaheim Hills, CA
08-25-2008, 06:30
Bus Standing TALL
Curt:
Some times the ride height valves need to go to the negative side then
return to the positive this resets the setting back to normal. Try
undocking and take a tour around the block then another block with right
and left turns and see if this corrects the problem. I agree, it is odd
they would all fail at the same time but then Murphy says" if it can
happen it will.?"
Safe travels,
84FC35 "Ruff Diamond"
Duncan, Oklahoma
Curt Sprenger
Anaheim Hills, CA
08-25-2008, 08:01
Bus Standing TALL
More Info...The height issue started a couple weeks back. Since then
the suspension has been lowered and raised several times, and the coach
has been driven a hundred miles, turning many corners, etc. All during
this time, when the suspension was aired up, it stood too tall. I just
now went out and cycled the suspension. When aired up it still stands
about 2" higher than normal.
On Mon, Aug 25, 2008 at 11:30 AM, Ralph L. Fullenwider <"rlf47@swbell.net"> wrote:
Curt:
happen it will.?"
Safe travels,
Duncan, Oklahoma
Curt Sprenger
Anaheim Hills, CA
Curt Sprenger
Anaheim Hills, CA
08-25-2008, 08:48
Bus Standing TALL
Curt there is an airpressure regulator involved and the only common denominator for all the air bags.
2008/8/25 Curt Sprenger <"curtsprenger@gmail.com">
Curt Sprenger
Anaheim Hills, CA
Rob, Sue & Merlin Robinson
94 WLWB
08-25-2008, 10:28
Bus Standing TALL
Right you are Rob. I picked up an Haldex pressure regulator. Now to get it installed.
Greg, is it OK if I come out and use your pit?
On Mon, Aug 25, 2008 at 1:48 PM, Rob Robinson <"wander.rob@gmail.com"> wrote:
Curt Sprenger
Anaheim Hills, CA
94 WLWB
Curt Sprenger
Anaheim Hills, CA
08-25-2008, 10:35
Bus Standing TALL
Curt I'd like to take the credit but can't. I passed your problem by Randy Dupree and it was his expertise that came up with the solution.
Curt Sprenger
Anaheim Hills, CA
94 WLWB
Curt Sprenger
Anaheim Hills, CA
94 WLWB
08-25-2008, 16:44
Bus Standing TALL
Curt, pit aint done but the keys are in the excavator and there is a
stack of trench plates by my bus. I got to get past the design and
just dig the hole. gunite and steel are paid for in swaps. kinda the
reason I have two gunite swimmingpools.
Greg
to get it
> installed.
> > Curt there is an air pressure regulator involved and the only
common
the rear of
cycled three
bad at the
> >> Curt Sprenger
> >> Anaheim Hills, CA
> > 94 WLWB
> Curt Sprenger
> Anaheim Hills, CA
