Sagging right front
06-21-2008, 05:13
Sagging right front
The right front corner of my coach is low. When I measure the ride
heights, both sides of the rear are identical, but the right front is
about an inch lower than the left front.
I did a lot of work on my old FC air suspension, so I am pretty
familiar with the system. If the rear ride heights are equal, that
tells me that the rear height control valves (which also control
left/right leveling) are working properly. Since the front has only
one valve, I am at a loss for how it can be out of whack when the rear
isn't.
Suggestions?
Scott Forman
86 PT38
Memphis
06-21-2008, 05:26
Sagging right front
Recycle the suspension a couple times and recheck. BB said the front (on the PT and might be the same for the FC) needs to be level. The '87 PT has one front leveling valve. To level the front, the rear could be off level (adjusted) and that is fine.
On Sat, Jun 21, 2008 at 10:13 AM, Scott Forman <"scottforman75@gmail.com"> wrote:
isn't.
Suggestions?
Scott Forman
86 PT38
Memphis
Curt Sprenger
Anaheim Hills, CA
06-21-2008, 06:46
Sagging right front
A couple of times I moved the coach some and bounce on the brake to get it equaled out. It's rare but has happened.
Leroy Eckert
1990 WB-40 Royale
Danlonega, GA
Smoke N Mirrors
--- On Sat, 6/21/08, Curt Sprenger wrote:
Subject: Re: [WanderlodgeForum] Sagging right front
Date: Saturday, June 21, 2008, 1:26 PM
isn't.
Suggestions?
Scott Forman
86 PT38
Memphis
Curt Sprenger
Anaheim Hills, CA
