Factory tour via Youtube
05-16-2008, 03:28
Ross,
Sorry to hear about your problems and hope they get
resolved reasonably. I went to the NHTSA link to view the
complaint but it appears some sort of NHTSA ODI
Number is required. Can you help?
Thanks,
David
'02 LXi, NC
Ross wrote:
Hi ,
There are many issues.
The move of the gennie to the 3rd bay is possibly a patch fix that
will not work in this coach. Left front -10,000 pounds and right side
8000 pounds with the bays empty. Moving the gennie to the left may
take 1/2 of its 960 pound weight off the front axle in total , but not
help the left side (This 450 has 2 slides only on left.)
The gennie in not on a slide. This is from Parliament site:
A shining example of our philosophies in action is our generator
installation. When Power Tech and Onan started offering generators in
the all-enclosed, boxed-in assembly, we carefully considered all the
benefits and drawbacks of such an installation. This installation
style affords a bit more space and ease of "assembly line"
installation, since these can be easily forklifted into place, as well
as reduced labor to custom-craft and line the generator compartment.
It does, however, severely impair its serviceability. For example,
the starter is located on the backside, necessitating generator
removal to repair or replace the starter or water pump and belt. That
may be relatively easy at the factory, but in the field it would prove
unacceptable. The generator's diesel engine is rated for the
equivalent of 500,000 miles of use before major work is needed, but we
all know from experience on our automobiles that a starter or starter
solenoid would need replacement long before that. Our end-slide
mounting of the generator affords access to all the generator
components.
Also note complaint on http://www-odi.nhtsa.dot.gov/
site
Legal is:
David W. Henry
Board Certified Civil Mediator
Allen Dyer Doppelt Milbrath & Gilchrist
255 So. Orange Ave.
Suite 1401
Orlando FL 32801
407.210.1486 direct
407.841.2330 main
407.841.2343 fax
www.addmg.com
--- In "WanderlodgeForum%40yahoogroups.com",
"JERRY SMITH" "medpro@..." wrote:
> Ross, what's the story? I know you bought about the same time I
did. You
> bought an 2006 LXI and I got a 2005 LXI. Have you got problems
with the
> coach?
> Jerry Smith
> 2005 450 LXI
> -------Original Message-------
> From: "WanderlodgeForum%40yahoogroups.com"
> Date: 05/16/08 09:51:02
> Subject: [WanderlodgeForum] Re: Factory tour via Youtube
> Hi,
> If I have a coach by then. Blue Bird lawyers!!
> Ross
"Curt Sprenger"
> > wrote:
> > Ross,
> > ALL RVs are invited. ...hope to see at Q2009.
> > On Mon, May 12, 2008 at 4:53 AM, Ross >
> > > Hi Curt,
> > > Not my nature to "be good".
> > > Enjoyed the last Q. Hope you'll invite us as SOB guests.
> > > Ross
> > > > Ross,
> > > > Thanks for bringing this to our attention. See you
again at Q
> > > 2009?...RIGHT?
> > > > Be good.
> > > > On Sun, May 11, 2008 at 5:08 PM, Ross
> > > > > http://www.youtube.com/watch?v=Pk1CfDQhY3c&feature=related
> > > > Curt Sprenger
> > > > 1987 PT38 8V92 "MacAttack Racing"
> > > > Anaheim Hills, CA
> > Curt Sprenger
> > Anaheim Hills, CA
Checked by AVG. Version: 7.5.524 / Virus Database: 269.23.16/1445 - Release Date: 5/15/2008 7:25 PM
