					Amp-Hours
					11-25-2007, 08:46
				Amp-Hours
					If I want to determine the total amp-hour capacity of my battery bank,
			do I multiply the AH rating of each battery by the number of batteries? Scott Forman 86 PT38 Memphis  |
					11-25-2007, 09:04
				Amp-Hours
					Scott just in case you haven't heard of this guy Phrannie here's some of his
			stuff. You'll love it. http://www.phrannie.org/battery.html On 25/11/2007, Scott Forman <sforman@...> wrote: > > If I want to determine the total amp-hour capacity of my battery bank, > do I multiply the AH rating of each battery by the number of > batteries? > > Scott Forman > 86 PT38 > Memphis > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed]  |
					11-25-2007, 10:28
				Amp-Hours
					If they are 12 v batteries, yes. For example, I have 6 model 4D 12v
			batteries. They have about 220 AH capacity (under ideal circumstances) so there are 6 x 220 = 1320 AH available. Of course, most batteries should not be discharged below 50% (deep cycle AGMs can go to 40% without damage), so you must divide the total AH by 2 to calculate the practical available AH (1320/2= 660 AH). Of course, the actual discharge rate will also affect the true number of amp hours any set of batteries can deliver. If you have 6 v batteries (on a 12 v system), then you have to divide the number of batteries by 2 -- in other words, Six 200 AH 6 v golf cart batteries will deliver the equivalent of three 12 v 200 AH batteries. Some of the older BBs carry 8 6V golf cart batteries of about 200 AH, so they have about 800 AH at 12 v or about 400 AH when you limit discharge to 50% as is suggested to not damage the batteries. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Lockhart, Texas On Nov 25, 2007, at 2:46 PM, Scott Forman wrote: > If I want to determine the total amp-hour capacity of my battery bank, > do I multiply the AH rating of each battery by the number of > batteries? > > Scott Forman > 86 PT38 > Memphis  |
