					air brakes wont relese
					10-30-2007, 11:49
					I just went to get my bus from its parking spot to bring it nearer to
			my shop to attempt replacing the water heater and the air brakes wont let me move it. When I push in the button after waiting for the pressure to get up to 120 the brakes stay engaged and the air pressure starts dropping steadilly untill I pull the button back out. I have never worked on the air brakes, what is the method for relesing them? I have the air suspension dumped, does that matter? I have it in a building that I just built and had to dump it to get it in because the ground is not level and with it up it almost hits the posts supporting the building. Robert Rahn Kalispell, Mt. 1988 pt 40  |
					10-30-2007, 12:00
					Robert,
			JMWAG...Try airing up the suspension, and then release the parking brakes...worth a try. On 10/30/07, Robert & Teri Rahn > > I just went to get my bus from its parking spot to bring it nearer to > my shop to attempt replacing the water heater and the air brakes wont > let me move it. When I push in the button after waiting for the > pressure to get up to 120 the brakes stay engaged and the air pressure > starts dropping steadilly untill I pull the button back out. I have > never worked on the air brakes, what is the method for relesing them? I > have the air suspension dumped, does that matter? I have it in a > building that I just built and had to dump it to get it in because the > ground is not level and with it up it almost hits the posts supporting > the building. > > Robert Rahn > Kalispell, Mt. > 1988 pt 40 > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed]  |
					10-30-2007, 12:00
					Robert my BB has a scheder (sp) valve in the rear of the engine compartment
			that lets a tow truck air up the bird in the event I lose air for any reason. You might try airing up this way to see if it loosens up whatever stuck valve or something else that is preventing the parking brake from taking on air and releasing. On 30/10/2007, Robert & Teri Rahn > > I just went to get my bus from its parking spot to bring it nearer to > my shop to attempt replacing the water heater and the air brakes wont > let me move it. When I push in the button after waiting for the > pressure to get up to 120 the brakes stay engaged and the air pressure > starts dropping steadilly untill I pull the button back out. I have > never worked on the air brakes, what is the method for relesing them? I > have the air suspension dumped, does that matter? I have it in a > building that I just built and had to dump it to get it in because the > ground is not level and with it up it almost hits the posts supporting > the building. > > Robert Rahn > Kalispell, Mt. > 1988 pt 40 > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed]  |
					10-30-2007, 12:46
					You may have a ruptured diaphragm on one of the rear brake units.  The rear
			brakes are your parking brakes and are engaged by a spring. If the air diaphragm that counteracts the spring has a hole in it the brake shoes will not release. Pressure up the air system and shut off the engine. Chock the tires for safety and have someone else push in the brake release. If you hear air leaking out of either side of the rear brakes you most likely lost a diaphragm or air hose. There is a way to manually release the spring brakes by backing out a very long bolt on the brake can, but you must be sure to do it safely. See forum post about working under air bag supported busses. Also I doubt that dumping your suspension has anything to do with the brakes since you are getting a full load of air. You can change out a diaphragm yourself, but if you are not familiar with it would suggest you get some help. Good luck and be careful, Jim Hutchings 1982 FCRB Yorba Linda, ca From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Robert & Teri Rahn Sent: Tuesday, October 30, 2007 3:49 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] air brakes wont relese I just went to get my bus from its parking spot to bring it nearer to my shop to attempt replacing the water heater and the air brakes wont let me move it. When I push in the button after waiting for the pressure to get up to 120 the brakes stay engaged and the air pressure starts dropping steadilly untill I pull the button back out. I have never worked on the air brakes, what is the method for relesing them? I have the air suspension dumped, does that matter? I have it in a building that I just built and had to dump it to get it in because the ground is not level and with it up it almost hits the posts supporting the building. Robert Rahn Kalispell, Mt. 1988 pt 40 [Non-text portions of this message have been removed]  |
