					86 PT leveling valve location
					10-21-2007, 11:54
					Where are the rear leveling valves on my PT?  My coach leans, and I
			fixed the same problem on my old FC by replacing a rear valve. Are they on the drive axle or tag? In front of it or behind? I am probably looking right at them and not seeing it, but I need a little help. Thanks Scott Forman 86 PT38 Memphis  |
					10-22-2007, 11:05
					Scott,
			If my memory serves me correctly (it usually does not) the last time I was under my '86 PT-40, the leveling rod could be seen just aft of the drive axle. I'll take a look next chance I get if you still have not loacted it. Regards, Glenn Allen 1986 PT-40 Marietta, GA --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Where are the rear leveling valves on my PT? My coach leans, and I > fixed the same problem on my old FC by replacing a rear valve. Are > they on the drive axle or tag? In front of it or behind? I am > probably looking right at them and not seeing it, but I need a little > help. > > Thanks > Scott Forman > 86 PT38 > Memphis >  |
