Air Pressure Problem
05-08-2005, 06:23
Hello again all,
Well now that all the planets are back in alignment (my travel has slowed
down, the weather is nice, some honeydoo's are completed) I am back to this
problem. I imagine all of you were on the right track but let me try to
describe it a little better. At the bottom of the cylinder is a small
philips head screw that secures a rubber washer to a round cap about the
size of a coke bottle cap (new style, not the old one we had to use a bottle
opener for) I put that in just in case any of you are old enough to remember
bottle openers. This cap has a triangular shape base and is attached to a
nut about 2 inches across by three small philips head screws. My question
is do I need to unscrew the big nut?
From the air dryer chalenged not so big nut.
Charles
Unscrew the part(4 screws) and take it to NAPA and get a new purge valve kit
Bendix part # BX287053 about $13.94. Install the new one.Its for a Bendix
AD-2 air dryer.
tom
1982 FC35
Ab
To:
Sent: Sunday, March 13, 2005 1:33 PM
Subject: [Wanderlodge] Air Pressure Problem
> Hi All,
> Just cranked up the bird (83 FC 35) and the air pressure doesn't come up.
> I have traced the problem to a vertical cylinder next to the drive shaft
> about midway of the coach. The air is escaping around a rubber washer
> secured by a small Philips head screw at the bottom of the cylinder.
> Should I just replace the rubber washer or is this a larger problem?
> Thanks,
> Charles
> 83 FC 35
> Stone Mountain GA
05-08-2005, 06:48
Still the same fix as the first time you asked back in March. Remove the
complete purge valve from the bottom and get a new kit and replace it. See
below the last time I posted this.
Tom
1982 FC35
Vernon Center,NY
At 02:23 PM 5/8/2005 -0400, you wrote:
>Hello again all,
>Charles
>AD-2 air dryer.
>tom
>1982 FC35
>Ab
>From:
>To:
> > Hi All,
> > Thanks,
> > Charles
> > 83 FC 35
> > Stone Mountain GA
>Yahoo! Groups Links
05-08-2005, 07:20
Tom,
I want to make sure we are talking about the same thing. This cylinder is
virtical, at the bottom below the cylinder itself is what I assume is the purge
valve. It has what I think is an air line going into it and also an electrical
lead. The three screws attach the leaking cap and three bolts attach the lower
part (pruge valve) I think to the cylinder. I don't see four screws anywhere.
Do you think it is the same thing maybe just a different mounting arrangement?
Charles
Sent: Sunday, May 08, 2005 2:48 PM
Subject: Re: [WanderlodgeForum] Air Pressure Problem
Tom
1982 FC35
Vernon Center,NY
>Hello again all,
>Charles
>AD-2 air dryer.
>tom
>1982 FC35
>Ab
>From:
>To:
> > Hi All,
> > Thanks,
> > Charles
> > 83 FC 35
> > Stone Mountain GA
>Yahoo! Groups Links
Yahoo! Groups Links
05-08-2005, 07:24
i lkie to remove the air dyer from the coach,take it inside,put it on a
table and work on it.i don't think that nut unscrews,i think its on there to
clock the end for hose alignment..randydupree93wb
To:
Sent: Sunday, May 08, 2005 2:23 PM
Subject: [WanderlodgeForum] Air Pressure Problem
> Hello again all,
> this
> bottle
> remember
> Charles
> kit
> AD-2 air dryer.
> tom
> 1982 FC35
> Ab
> From:
> To:
>> Hi All,
>> up.
>> Thanks,
>> Charles
>> 83 FC 35
>> Stone Mountain GA
> Yahoo! Groups Links
05-08-2005, 08:33
Hi Charles:
There is a large hex looking body that unscrews from the lid. The purge
valve is in there. Some times it takes mounting the lid gently in a vice
and tapping the wrench connected to the hex below the lid to get it to
separate then it just un screws. Then you will need a large blade screw
driver and a 7/16" socket to remove the purge valve with.
Good luck
Safe travels,
Ralph Fullenwider
Dream_35_Team
'85FC35 in Oklahoma
Ralph's RV Solutions
At 03:20 PM 5/8/2005 -0400, you wrote:
>Tom,
>purge valve. It has what I think is an air line going into it and also an
>electrical lead. The three screws attach the leaking cap and three bolts
>attach the lower part (pruge valve) I think to the cylinder. I don't see
>four screws anywhere. Do you think it is the same thing maybe just a
>Charles
> From: Tom Warner
> Tom
> 1982 FC35
> Vernon Center,NY
> >Hello again all,
> this
> bottle
> remember
> >Charles
> valve kit
> >AD-2 air dryer.
> >tom
> >1982 FC35
> >Ab
> >From:
> >To:
> > > Hi All,
> come up.
> shaft
> > > Thanks,
> > > Charles
> > > 83 FC 35
> > > Stone Mountain GA
05-08-2005, 09:56
Ralph, YOU THE MAN
The hex body came off with everything still mounted on the coach. Took it
apart. Some gunk inside. The O rings still look in good shape but thats not
uncommon. Will get the kit this week.
Thanks,
Charles
Sent: Sunday, May 08, 2005 4:33 PM
Hi Charles:
Good luck
Safe travels,
Ralph Fullenwider
Dream_35_Team
'85FC35 in Oklahoma
>Tom,
>Charles
> From: Tom Warner
> Tom
> 1982 FC35
> Vernon Center,NY
> >Hello again all,
> this
> bottle
> remember
a
question
> >Charles
> valve kit
> >AD-2 air dryer.
> >tom
> >1982 FC35
> >Ab
> >From:
> >To:
> > > Hi All,
> come up.
> shaft
> > > Thanks,
> > > Charles
> > > 83 FC 35
> > > Stone Mountain GA
Yahoo! Groups Links
05-13-2005, 12:31
Have you replaced the air governor on the compressor under the dog
house? It signals the purge valve to dump, and is likely the root
cause.
Dan
94 BMC 37'
--- In WanderlodgeForum@yahoogroups.com, wrote:
> Ralph, YOU THE MAN
Took it apart. Some gunk inside. The O rings still look in good
shape but thats not uncommon. Will get the kit this week.
> Thanks,
> Charles
> From: Ralph L. Fullenwider
> Hi Charles:
The purge
in a vice
it to
blade screw
> Good luck
> Safe travels,
> Ralph Fullenwider
> Dream_35_Team
> '85FC35 in Oklahoma
> >Tom,
cylinder is
assume is the
and also an
three bolts
don't see
just a
> >Charles
> > From: Tom Warner
March. Remove the
replace it. See
> > Tom
> > 1982 FC35
> > Vernon Center,NY
> > >Hello again all,
travel has slowed
am back to
> > this
let me try to
is a small
cap about the
had to use a
> > bottle
enough to
> > remember
is attached to a
screws. My question
> > >Charles
new purge
> > valve kit
> > >AD-2 air dryer.
> > >tom
> > >1982 FC35
> > >Ab
> > >From:
> > >To:
> > > > Hi All,
pressure doesn't
> > come up.
the drive
> > shaft
rubber washer
the cylinder.
larger problem?
> > > > Thanks,
> > > > Charles
> > > > 83 FC 35
> > > > Stone Mountain GA
> Yahoo! Groups Links
of Service.
