How often do you check your battery level water?
09-13-2007, 08:15
So far with my single battery cooker, I check mine once a month. No
problems, so far. Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] |
09-13-2007, 08:35
I saw Ralph install one of those on Wallace's PT 40. Sure is a neat system.
09-13-2007, 10:38
In a message dated 9/13/2007 6:47:25 P.M. Mountain Standard Time,
jipjob@... writes: When you go those RV sales lots, you the ones that have millions and millions dollars worth of stock how do they maintain those units befor sale time Most are plugged into elec. Some are not. I had my 35FC for sale at a consignment lot, years ago. The management said the coach would always have electricity. I went there 3 weeks later, no electricity, no sales person to bug ya.Dead batteries-- I had to crawl under coach to attach jumper cables to genny battery to start generator and then fired the coach up. Drove it off that consignment lot and didn't look back. Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] |
09-13-2007, 12:04
Well this probably is an old subject but its interesting to think that
this is probably one of the most over looked items on our coaches. I try to remember once a month to refill my battery's because of a cost of over 350 dollars for four battery's this an easy solution. All these items such as such battery tenders and whatnot's still those items will not let you know that your battery acid water is below the plates. So does anyone here have any horror stories to tell about this most forgetful item? Jipjob 78 Wanderlodge |
09-13-2007, 12:13
--- In WanderlodgeForum@yahoogroups.com, "Jon"
> > Well this probably is an old subject but its interesting to think that > this is probably one of the most over looked items on our coaches. I > try to remember once a month to refill my battery's because of a cost > of over 350 dollars for four battery's this an easy solution. All > these items such as such battery tenders and whatnot's still those > items will not let you know that your battery acid water is below the > plates. So does anyone here have any horror stories to tell about this > most forgetful item? > Jipjob > 78 Wanderlodge > I was kind of wondering about our friends who have the 200,000 dollars rigs how often do you guys take a peak at your batterys? Jipjob |
09-13-2007, 12:31
Why dont you install a single point battery watering system
http://capeinnovation.com/singlepoint/ Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Jon" > > Well this probably is an old subject but its interesting to think that > this is probably one of the most over looked items on our coaches. I > try to remember once a month to refill my battery's because of a cost > of over 350 dollars for four battery's this an easy solution. All > these items such as such battery tenders and whatnot's still those > items will not let you know that your battery acid water is below the > plates. So does anyone here have any horror stories to tell about this > most forgetful item? > Jipjob > 78 Wanderlodge > |
09-13-2007, 13:44
> > I saw Ralph install one of those on Wallace's PT 40. Sure is a neat system. > > Ernie Ekberg > 83PT40 > Livingston, Mt > > > > > ************************************** See what's new at http://www.aol.com > > > [Non-text portions of this message have been removed] Do the newer Wanderlodge coaches come with this single point device? Looks like a winner for a sure cure for that low water problem in our batterys. When you go those RV sales lots, you the ones that have millions and millions dollars worth of stock how do they maintain those units befor sale time. Jipjob Rebel Bird > |
09-13-2007, 15:38
Jipjob
Untill I installed a "Smart Battery Charger" they needed checking once a week. Now once a month is fine. Having a 79FC checking the batteries is a challange to say the least. I made a battery filler/checker. I used a water alarm it's sold for warning you of a flooded basement. I made 2 probes that are the correct length for my batteries this is the checker section. The filler consists of a gallon jug and a small hand pump. The tube from the pump has the probes on it. Stick the end in each cell and add water untill the alarm sounds. Now it takes more time to remove the caps. Cost less than 30$. The auto filler sounds great, but I like to check the cables and compartment as well. Picky 79FC33SB On Thursday, September 13, 2007, at 05:04 PM, Jon wrote: > Well this probably is an old subject but its interesting to think that > this is probably one of the most over looked items on our coaches. I > try to remember once a month to refill my battery's because of a cost > of over 350 dollars for four battery's this an easy solution. All > these items such as such battery tenders and whatnot's still those > items will not let you know that your battery acid water is below the > plates. So does anyone here have any horror stories to tell about this > most forgetful item? > Jipjob > 78 Wanderlodge > > |
09-13-2007, 16:33
For my money you can't beat AGM batteries. Lots going for them, and never having
to check fluid levels is just one of them. Don Bradner 90 PT40 "Blue Thunder" Posting today by satellite from Salt Lake City, headed for Cheyenne in a couple of days. On 9/14/2007 at 12:04 AM Jon wrote: >Well this probably is an old subject but its interesting to think that >this is probably one of the most over looked items on our coaches. I >try to remember once a month to refill my battery's because of a cost >of over 350 dollars for four battery's this an easy solution. All >these items such as such battery tenders and whatnot's still those >items will not let you know that your battery acid water is below the >plates. So does anyone here have any horror stories to tell about this >most forgetful item? >Jipjob >78 Wanderlodge |
