					Toilet emergency...time estimate
					09-02-2007, 02:34
					Thanks all I am enjoying talking Birds.
			Hmm, Howard, you might be right, I did add 15 minutes for drinking that beer that was grabbed on the way by the refer. Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma At 10:11 AM 9/2/2007 -0400, you wrote: >Ralph, >Brother,It is so good to see your post and hopefully you are feeling better. >I read your instructions for Scott. One thing you should consider adding >in the future concerning your time estimate. >Ralphs time 1 hr. 15 min., Novice time 7 hrs. 47 min. Plus. >Howard Truitt >Camilla, Ga. >Sowega [South West Georgia] >86, 8V92, PT40 > > > ----- Original Message ----- > From: Ralph L. Fullenwider > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, September 01, 2007 9:36 PM > Subject: Re: [WanderlodgeForum] Re: Toilet emergency...Help! > > > Hi Scott: > > Your going to need a ball valve replacement package. If your commode is > the > original and is the starlight or galaxy, the part number is #09868 and > there should be the needed replacement instructions. > > But a couple of short cuts might help. 1. Turn off the water and look > where > the water hooks up to the ball valve and un screw the nut holding the tube > to the valve. 2. Open the top lids and on your left as you face the front > of the unit you will see a circle plastic piece that is flush, with a > small > knife blade pry it up and out but take care not to bang it up too much. > > Now then there are 2 screws with nuts that hold the unit to the floor and > with a flash light peer down the hold of the cover you just removed, I use > a 3/8 drive 18 inch extension, a swivel and a deep well socket to loosen > and remove that nut. Then with a long stout screw driver, press down on > the > foot pedal and use the long stout screwdriver to hold it down, now you can > see the second nut that must be removed. The commode is now up and out the > door to work on, oh, grab a beer on the way by the refer. > > You are going to have to remove the flush mechanism to replace the ball > valve and should find some 8 or so screws around the base holding the > flush > mech to the bowl, there are also 2 hoses held on by crimp hose clamps that > must be removed. Now the base is off and you can see where you have to go. > Whole job should take you about 1 hr 15 minutes or so from out to in > and done. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Duncan, Oklahoma > > At 01:01 AM 9/2/2007 +0000, you wrote: > >Mine has a cut-off, thankfully. > > > >Still need to know how to fix it. > > > >Scott > > > >  |
