Firestone Accu-forge wheels
08-22-2007, 11:46
Post: #21
you got stud centered. crack testing will require dismounting, through cleaning
a subjection to a "Zyglow" process. Not real cheap procedure. Industrial testing facilities can provide. If you have visable cracks in the hub area, the wheel is scrap. MH ----- Original Message ----- From: mrkane1952 To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, August 22, 2007 4:09 PM Subject: [WanderlodgeForum] Re: Firestone Accu-forge wheels Greetings All: I've posted a picture of the questionable wheel in an album named "Cracked Wheel." The "defect" is a little over 3.5 inches long, and ends about 3 inches from the rim. Perhaps the group could take a look and suggest whether replacement is needed. I found a website with prices for a vendor in Dallas: <http://www.hdpsales.com/alcoahub.htm>. Example prices run $300-$400 each for 22.5" x 8.25" wheels. Are our wheels hub-centered? I'm also confused which is the "inside" and "outside" of the wheel? The convex side is visible when mounted on my steer axle, the concave side is visible on the tag and drive axles? Is wheel testing available for aluminum like magnafluxing for steel? Thanks-- M.R.Kane 1985 PT 40 Sanger, TX --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > Yeah, Mike Hohnstein has real good prices on those wheels. If you > can see an obvious crack and it is building up dirt, it's cracked all > the way through. Common occurrence from them countryside burly tire > changers with 1,000+lb of torque 1" air guns cranked to the max. > Don't ask how I know! > > Speaking of cracks however, a single small stress crack emanating > outward from a lug nut hole is not a major deal requiring immediate > fix. However, one (or more) that goes from a lug nut hole all the way > to the center flange, or one that goes from one lug hole to another > lug nut hole, well those are roadside events waiting to happen and > worthy of quickly fixing... > > Mike Bulriss > 1991 WB40 "Texas Mininvan" > San Antonio, TX > [Non-text portions of this message have been removed] |
08-23-2007, 00:28
Post: #22
There would be no question in my mind. That wheel would be gone!
Steve Anderson 1979 FC 35 Poulsbo Wa In a message dated 8/23/2007 9:00:51 AM Pacific Daylight Time, nom_descono@... writes: --- In _WanderlodgeForum@WanderlodgeFWan_ (mailto:WanderlodgeForum@yahoogroups.com) , "mrkane1952" <mrkane@...> wrote: > Greetings All: > > I've posted a picture of the questionable wheel in an album named > "Cracked Wheel." The "defect" is a little over 3.5 inches long, and > ends about 3 inches from the rim. Perhaps the group could take a look > and suggest whether replacement is needed. > > I found a website with prices for a vendor in Dallas: > <_http://www.hdpsaleshttp://www.hdphtt_ (http://www.hdpsales.com/alcoahub.htm) >. Example prices run $300-$400 > each for 22.5" x 8.25" wheels. > > Are our wheels hub-centered? I'm also confused which is the "inside" > and "outside" of the wheel? The convex side is visible when mounted > on my steer axle, the concave side is visible on the tag and drive axles? > > Is wheel testing available for aluminum like magnafluxing for steel? > > Thanks-- > > M.R.Kane > 1985 PT 40 > Sanger, TX > > > --- In _WanderlodgeForum@WanderlodgeFWan_ (mailto:WanderlodgeForum@yahoogroups.com) , "mbulriss" <mbulriss@> wrote: > > > > Yeah, Mike Hohnstein has real good prices on those wheels. If you > > can see an obvious crack and it is building up dirt, it's cracked all > > the way through. Common occurrence from them countryside burly tire > > changers with 1,000+lb of torque 1" air guns cranked to the max. > > Don't ask how I know! > > > > Speaking of cracks however, a single small stress crack emanating > > outward from a lug nut hole is not a major deal requiring immediate > > fix. However, one (or more) that goes from a lug nut hole all the way > > to the center flange, or one that goes from one lug hole to another > > lug nut hole, well those are roadside events waiting to happen and > > worthy of quickly fixing... > > > > Mike Bulriss > > 1991 WB40 "Texas Mininvan" > > San Antonio, TX > > > > The wheels on the front axle are polished outside, outside rears are polished inside. I looked at your file picture. The crack doesn't appear to run between any two holes. However, it's on the front so it must be replaced. *Danger Will Robinson* What a wild ride that would be!! Harold Prescott '85 FC35 Bangor, California ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] |
08-23-2007, 03:58
Post: #23
--- In WanderlodgeForum@yahoogroups.com, "mrkane1952" <mrkane@...> wrote:
> Greetings All: > > I've posted a picture of the questionable wheel in an album named > "Cracked Wheel." The "defect" is a little over 3.5 inches long, and > ends about 3 inches from the rim. Perhaps the group could take a look > and suggest whether replacement is needed. > > I found a website with prices for a vendor in Dallas: > <http://www.hdpsales.com/alcoahub.htm>. Example prices run $300-$400 > each for 22.5" x 8.25" wheels. > > Are our wheels hub-centered? I'm also confused which is the "inside" > and "outside" of the wheel? The convex side is visible when mounted > on my steer axle, the concave side is visible on the tag and drive axles? > > Is wheel testing available for aluminum like magnafluxing for steel? > > Thanks-- > > M.R.Kane > 1985 PT 40 > Sanger, TX > > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> wrote: > > > > Yeah, Mike Hohnstein has real good prices on those wheels. If you > > can see an obvious crack and it is building up dirt, it's cracked all > > the way through. Common occurrence from them countryside burly tire > > changers with 1,000+lb of torque 1" air guns cranked to the max. > > Don't ask how I know! > > > > Speaking of cracks however, a single small stress crack emanating > > outward from a lug nut hole is not a major deal requiring immediate > > fix. However, one (or more) that goes from a lug nut hole all the way > > to the center flange, or one that goes from one lug hole to another > > lug nut hole, well those are roadside events waiting to happen and > > worthy of quickly fixing... > > > > Mike Bulriss > > 1991 WB40 "Texas Mininvan" > > San Antonio, TX > > > > The wheels on the front axle are polished outside, outside rears are polished inside. I looked at your file picture. The crack doesn't appear to run between any two holes. However, it's on the front so it must be replaced. *Danger Will Robinson* What a wild ride that would be!! Harold Prescott '85 FC35 Bangor, California |
