Jabco water pressure regulator.
07-02-2007, 03:55
Anyone had experience changing the water pressure regulator, and
where can you get a compatible unit? I believe the original was
manufactured by Jabco.
Chuck Harrison
A kron, Ohio
90 SP36
07-02-2007, 04:10
Is that Jabco or Jabsco?
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of williamcharrison
Sent: Monday, July 02, 2007 8:56 AM
Subject: [WanderlodgeForum] Jabco water pressure regulator.
Chuck Harrison
A kron, Ohio
90 SP36
07-02-2007, 04:29
Sureflo also makes a replacement that should fit. But, IMO, replace
it with a Watts, home type regulator. See the 4 pictures of mine at
this link:
http://www.photosleeve.com/v/Gman/Regula...8.JPG.html
Improved water flow and beter protection. Most RV water regulators
are good for less than 1 gpm.
Rich D. '99LXi43' CT
> Chuck Harrison
> A kron, Ohio
> 90 SP36
07-02-2007, 04:31
Chuck,
I sent you pictures of what I did when our regulator stopped working.
The pictures are also out on one of, or both forums.
Curt Sprenger
Anaheim Hills, Calif.
> Chuck Harrison
> A kron, Ohio
> 90 SP36
