Pac brake
06-22-2007, 15:19
Pac brake
I know I have seen the answer to this but I can't find it. Is the
3208/Allison MT 643 and Pac Brake a good combination? Thanks in advance. New Guy Brad Bloxham 78 35' Idaho Falls. |
06-22-2007, 16:21
Pac brake
Ya know when I had the '81FC with the same power and tranny as yours I wondered
the same thing. The people that sell Pac Brake said sure. But, I talked to several Cat people about it at different rallies and they all said about the same thing - "Cat does not recommend it". The bad part is I can't remember why. I do remember that it wasn't a reason I could readily understand. I no longer have the bus so it is a non-issue to me now. It just seemed to me it should work. Good luck. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: kingmtpg To: WanderlodgeForum@yahoogroups.com Sent: Friday, June 22, 2007 8:19 PM Subject: [WanderlodgeForum] Pac Brake I know I have seen the answer to this but I can't find it. Is the 3208/Allison MT 643 and Pac Brake a good combination? Thanks in advance. New Guy Brad Bloxham 78 35' Idaho Falls. [Non-text portions of this message have been removed] |
06-23-2007, 01:13
Pac brake
Have you done a search in this forum on that subject. I asked that
question maybe a year ago. I think it was Randy Dupree or Mike Hohnstein that answered. Apparently youi will get little or no braking on a 3208. Something to do with vaklve springs and how the engine breathes. I had considered a driveline brake but the cost is out of sight. Bruce 1988 FC35 |
06-24-2007, 19:25
Pac brake
the short fall of the pac brake on a 3208 is number one the exhaust valve
springs on a na are not heavy enough and will float under the back pressure of a pac brake, if you have a turbo your are limited to I believe 25/28 lbs of back pressure, which does not give the same results as on other diesels which can run much higher pressures, I did install one on a 3208 ta in my 8235fc, it wasn"t worth it. gear down and pump the brakes on the big hills. ron 95pt40 brandon fl ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
