Electro Luminescent Dash
05-18-2007, 16:50
Post: #31
I've been in the dash a number of times so far, but I didn't even know the pyro
light was out. On 5/18/2007 at 9:11 PM Rob Robinson wrote: >Nice shot Don. I see you have a light out, maybe the Pyro? Have you ever >opened up the dash to replace bulbs? > >On 18/05/07, Don Bradner >> >> I couldn't resist having a crack at a picture. The result is a >> compromise between making the dash bright enough, and still showing the >> bluebird high beam indicator. I don't drive at night, or hardly ever, so >I >> didn't even know my Turbo Pyrometer has a burnt out light bulb! >> >> Picture can be seen at >> http://www.arcatapet.net/travel/images/9...g_3984.jpg >> >> Don Bradner >> 90 PT40 "Blue Thunder" >> Posting on the road by satellite from >> Portland, Oregon |
05-18-2007, 17:04
Post: #32
I have a few bulbs I'd like to replace. Does the dash lift up easily?
On 18/05/07, Don Bradner > > I've been in the dash a number of times so far, but I didn't even know > the pyro light was out. > > On 5/18/2007 at 9:11 PM Rob Robinson wrote: > > >Nice shot Don. I see you have a light out, maybe the Pyro? Have you ever > >opened up the dash to replace bulbs? > > > >On 18/05/07, Don Bradner > wrote: > >> > >> I couldn't resist having a crack at a picture. The result is a > >> compromise between making the dash bright enough, and still showing the > >> bluebird high beam indicator. I don't drive at night, or hardly ever, > so > >I > >> didn't even know my Turbo Pyrometer has a burnt out light bulb! > >> > >> Picture can be seen at > >> http://www.arcatapet.net/travel/images/9...g_3984.jpg > >> > >> Don Bradner > >> 90 PT40 "Blue Thunder" > >> Posting on the road by satellite from > >> Portland, Oregon > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
05-18-2007, 17:15
Post: #33
It does on mine. Pull the screws, and use something gently at a corner to lift
it and work around from there. On 5/18/2007 at 10:04 PM Rob Robinson wrote: >I have a few bulbs I'd like to replace. Does the dash lift up easily? > >On 18/05/07, Don Bradner >> >> I've been in the dash a number of times so far, but I didn't even know >> the pyro light was out. >> >> On 5/18/2007 at 9:11 PM Rob Robinson wrote: >> >> >Nice shot Don. I see you have a light out, maybe the Pyro? Have you ever >> >opened up the dash to replace bulbs? >> > >> >On 18/05/07, Don Bradner > >> wrote: >> >> >> >> I couldn't resist having a crack at a picture. The result is a >> >> compromise between making the dash bright enough, and still showing >the >> >> bluebird high beam indicator. I don't drive at night, or hardly ever, >> so >> >I >> >> didn't even know my Turbo Pyrometer has a burnt out light bulb! >> >> >> >> Picture can be seen at >> >> http://www.arcatapet.net/travel/images/9...g_3984.jpg >> >> >> >> Don Bradner >> >> 90 PT40 "Blue Thunder" >> >> Posting on the road by satellite from >> >> Portland, Oregon |
05-18-2007, 17:22
Post: #34
Thanks. I've heard some of the older dashboards are a bear to work on.
On 18/05/07, Don Bradner > > It does on mine. Pull the screws, and use something gently at a corner > to lift it and work around from there. > > On 5/18/2007 at 10:04 PM Rob Robinson wrote: > > >I have a few bulbs I'd like to replace. Does the dash lift up easily? > > > >On 18/05/07, Don Bradner > wrote: > >> > >> I've been in the dash a number of times so far, but I didn't even know > >> the pyro light was out. > >> > >> On 5/18/2007 at 9:11 PM Rob Robinson wrote: > >> > >> >Nice shot Don. I see you have a light out, maybe the Pyro? Have you > ever > >> >opened up the dash to replace bulbs? > >> > > >> >On 18/05/07, Don Bradner > > > > >> wrote: > >> >> > >> >> I couldn't resist having a crack at a picture. The result is a > >> >> compromise between making the dash bright enough, and still showing > >the > >> >> bluebird high beam indicator. I don't drive at night, or hardly > ever, > >> so > >> >I > >> >> didn't even know my Turbo Pyrometer has a burnt out light bulb! > >> >> > >> >> Picture can be seen at > >> >> http://www.arcatapet.net/travel/images/9...g_3984.jpg > >> >> > >> >> Don Bradner > >> >> 90 PT40 "Blue Thunder" > >> >> Posting on the road by satellite from > >> >> Portland, Oregon > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
05-19-2007, 02:33
Post: #35
That came out pretty well... and it looks more "green" in the photo
than the blue I sense when I see it in person... Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Lockhart Texas On May 18, 2007, at 10:55 PM, Don Bradner wrote: > I couldn't resist having a crack at a picture. The result is a > compromise between making the dash bright enough, and still showing > the bluebird high beam indicator. I don't drive at night, or hardly > ever, so I didn't even know my Turbo Pyrometer has a burnt out > light bulb! > > Picture can be seen at http://www.arcatapet.net/travel/images/ > 90pt40/img_3984.jpg |
05-19-2007, 03:00
Post: #36
Don, I'm astonished. That is so beautiful! You've done a nice job
photographing a difficult subject. You and Bill should upload your pics to the Photos section. Thank you so much for the effort. Ginger BB wannabee --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > I couldn't resist having a crack at a picture. > > Picture can be seen at http://www.arcatapet.net/travel/images/9...g_3984.jpg |
05-19-2007, 04:15
Post: #37
OK, I created an album called "Dash Pictures" and uploaded it there along with a
daylight picture of the same dash - pictures of other dashes, day or night, would be welcome in that album. Too bad they don't show the original-size picture! On 5/19/2007 at 3:00 PM runnerful wrote: >Don, I'm astonished. That is so beautiful! You've done a nice job >photographing a difficult subject. You and Bill should upload your >pics to the Photos section. > >Thank you so much for the effort. > >Ginger >BB wannabee > >--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > >> >> I couldn't resist having a crack at a picture. > >> Picture can be seen at >http://www.arcatapet.net/travel/images/9...g_3984.jpg > > > > > >Yahoo! Groups Links > > > |
05-19-2007, 08:28
Post: #38
<MHOHNSTEIN@...> wrote: For sure mine are Blue. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, Fl Posting from Salt Springs Resort, Ocala National Forest > > I'm down with the green. > MH > ----- Original Message ----- > From: Ryan Wright > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, May 18, 2007 4:03 PM > Subject: Re: [WanderlodgeForum] Re: Electro Luminescent Dash > > > Don: > > > Pete Unless I'm color blind I think mine are a shade of green. > > Mine look to be a shade of green as well. Maybe we're both color blind. ![]() > > Ginger: > > > When I first began evaluating BBs I was amazed to see central vacs, > > ice makers, Corian counters, hydrolic levelers, air ride suspensions > > and more in 20 year old coaches. > > Yup. That's exactly why I fell in love with these old coaches. I've > had mine only a few weeks now and am loving every minute of it. Beats > the tar out of any of those new coaches they sell down at the local RV > dealerships. > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA > > > > > [Non-text portions of this message have been removed] > |
05-19-2007, 13:40
Post: #39
Hi Don,
--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > OK, I created an album called "Dash Pictures" and uploaded it there along with a daylight picture of the same dash - pictures of other dashes, day or night, would be welcome in that album. Too bad they don't show the original-size picture! Excellent. Good job. You're right though, the bigger pic looks more spectacular. Ginger BB wannabee |
User(s) browsing this thread: 17 Guest(s)
