88 power problem update
02-11-2007, 12:44
--- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote:
Arriving at Quartszite for the rally a cuppala weeks ago I fired off genny and found I had lost AC power to the house. It was working when I left. Applying forum knowledge, I checked the fuses and breakers on genny. Without success, I came to the conclusion I'd lost the master switch next to the passenger seat. As a last resort (shuda been the first), I went into the closet housing the main breaker box and found that the last thing I did before leaving was to push clothes on hangers onto the clothes rack inadvertently turning off the master breaker. Whodathunkit? Add item: Close break box door in closet after use Ron, No. California 85PT36 > > Leroy, > > That's not a bad little check list even if you if you don't think you > are experiencing a power failure. In the fog and confusion of an "Oh, > crap" moment, it is all too easy to overlook the basics. |
02-11-2007, 15:27
Thank you so much. Mine is in the same place. I will place it on the list.
Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Ron & Patty To: WanderlodgeForum@yahoogroups.com Sent: Sunday, February 11, 2007 6:44 PM Subject: [WanderlodgeForum] Re: 88 power problem update --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: Arriving at Quartszite for the rally a cuppala weeks ago I fired off genny and found I had lost AC power to the house. It was working when I left. Applying forum knowledge, I checked the fuses and breakers on genny. Without success, I came to the conclusion I'd lost the master switch next to the passenger seat. As a last resort (shuda been the first), I went into the closet housing the main breaker box and found that the last thing I did before leaving was to push clothes on hangers onto the clothes rack inadvertently turning off the master breaker. Whodathunkit? Add item: Close break box door in closet after use Ron, No. California 85PT36 > > Leroy, > > That's not a bad little check list even if you if you don't think you > are experiencing a power failure. In the fog and confusion of an "Oh, > crap" moment, it is all too easy to overlook the basics. [Non-text portions of this message have been removed] |
