FC Bay Door Problem
02-10-2007, 05:24
FC Bay Door Problem
One of my FC bay doors is not opening correctly, something is wrong
with the latch mechanism. When I pull the handle, one side unlatches, but the other doesn't. To open the door, I must pull the unlatched side open far enough to slide a crow bar up inside the door, at hwich time I can snag the cable attached to the latch and pop it open. Nothing is broken on the whole mechanism, it just seems to be out of adjustment, but I can;t see how to fix it. Suggestions? Scott Forman 82 FC35RB Memphis |
02-10-2007, 05:39
FC Bay Door Problem
Scott,
I had the same problem once. The striker on the problem side needed to be adjusted. Hold a mirror behind the striker and you will see the adjustment slots. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Scott Forman wrote: > One of my FC bay doors is not opening correctly, something is wrong > with the latch mechanism. When I pull the handle, one side unlatches, > but the other doesn't. To open the door, I must pull the unlatched > side open far enough to slide a crow bar up inside the door, at hwich > time I can snag the cable attached to the latch and pop it open. > Nothing is broken on the whole mechanism, it just seems to be out of > adjustment, but I can;t see how to fix it. > > Suggestions? > > Scott Forman > 82 FC35RB > Memphis > > |
02-10-2007, 10:14
FC Bay Door Problem
wrote: > > One of my FC bay doors is not opening correctly, something is wrong > with the latch mechanism. When I pull the handle, one side unlatches, > but the other doesn't. To open the door, I must pull the unlatched > side open far enough to slide a crow bar up inside the door, at hwich > time I can snag the cable attached to the latch and pop it open. > Nothing is broken on the whole mechanism, it just seems to be out of > adjustment, but I can;t see how to fix it. > > Suggestions? > > Scott Forman > 82 FC35RB > Memphis > bay door if you want to see how the latch works go to your propane door and lay on the ground. you can then open and close the bay door and watch the latches work. could be your cable out of adjustment ed and peggy "lonesome dove" 1983fc-35rb |
