Window Replacement Source
05-29-2006, 15:17
Mike....I used Jeff Kemp with Peninsula Glass 1-800-468-4323. He will
cut you a new piece of the same glass. Be sure and tell him what size and what tint you need. He will ship you a slightly larger piece. Remove the whole window frame from the coach by working the gasket out. It's not too hard to remove. Then take the frame and your new piece of glass to your local big glass company and get them to cut and install it in the frame. Mine charged me $50. Now comes the hard part, reinstalling the frame back in the coach. Go slow, have a helper, use some soapy water for lubricant....Good luck Rick Archie 85 PT 40 Fort Worth, TX |
