Silcone Remover
05-20-2006, 16:51
Silcone Remover
Every once in a while I have had to remove silicone and came across the
following recommendations. Anyone care to comment on these products? 1. Silicone remover made by liquid nails - Lowes 2. 3M Silicone & Adhesive Remover - Automotive Paint Store 3. McKanica Silicone Calk Remover Gel (0354) - Ace Hardware -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
05-21-2006, 00:52
Silcone Remover
Just dont get it on any stained or painted surface
Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > Every once in a while I have had to remove silicone and came across the > following recommendations. Anyone care to comment on these products? > > 1. Silicone remover made by liquid nails - Lowes > 2. 3M Silicone & Adhesive Remover - Automotive Paint Store > 3. McKanica Silicone Calk Remover Gel (0354) - Ace Hardware > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > |
05-21-2006, 02:58
Silcone Remover
Rob, the 3m products always seem to do what they say. I use WD40
first, (WD40 is also good for removing pvc glue from skin.) When the 3M adhesive remover wont work, I tape off the area and use gasket remover. Gasket remover seems to reduce the mass allowing 3M adhesive remover to lift the interface. 3M R&D is A1. G O'C pt40 R Ca --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > Every once in a while I have had to remove silicone and came across the > following recommendations. Anyone care to comment on these products? > > 1. Silicone remover made by liquid nails - Lowes > 2. 3M Silicone & Adhesive Remover - Automotive Paint Store > 3. McKanica Silicone Calk Remover Gel (0354) - Ace Hardware > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > |
