Diesel Generator Question
04-22-2006, 15:44
Does anyone out there know how/where I can get a wiring diagram for
the control box/start/stop switch?. It's an 83 35FC SB with the 12.5KW Perkins diesel gen. I believe the switch has been replaced and was wired wrong. Was able to start by putting a screwdriver to the relay. I also believe there could be a problem with that relay as well. This BB has set for at least a year and will need some work but runs well. Should run better now that the dried grass has been removed from the air intake/filter. Guess some animal used it to make a nest. I am amazed that this thing even would run the way it was. It was clogged with grass!! Removed all the grass, vacuumed all the grass from around the engine area and all the old doghouse insulation that was all over the engine. This might explain some smoke that was coming from the engine on the drive over....I'll post some pictures of all this mess soon... And even The Horn works.... Chris Reed Plant City,FL Soon to be owner of 83 FC35 SB contingent on house sale |
04-22-2006, 15:47
Chris, you will find schematics in the files section of the Forum.
Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 03:44 AM 4/23/2006 +0000, you wrote: >Does anyone out there know how/where I can get a wiring diagram for >the control box/start/stop switch?. It's an 83 35FC SB with the 12.5KW >Perkins diesel gen. I believe the switch has been replaced and was >wired wrong. Was able to start by putting a screwdriver to the relay. >I also believe there could be a problem with that relay as well. >This BB has set for at least a year and will need some work but runs >well. Should run better now that the dried grass has been removed from >the air intake/filter. Guess some animal used it to make a nest. I am >amazed that this thing even would run the way it was. It was clogged >with grass!! Removed all the grass, vacuumed all the grass from around >the engine area and all the old doghouse insulation that was all over >the engine. This might explain some smoke that was coming from the >engine on the drive over....I'll post some pictures of all this mess >soon... >And even The Horn works.... > >Chris Reed >Plant City,FL >Soon to be owner of 83 FC35 SB contingent on house sale > > > |
