Samsung refer simple door lock
09-14-2014, 21:48
I put in a set of tank batteries and ran a test of inverted powers ability to run my shop refer. I forgot about the 8 hour test and was surprised when the batteries were still running the 16 year old refer three days later. so I removed the Dometic 7030 ($500.00 if you need one) and put in a Samsung model with guidance from Peter H and Robbie the other Canadian. her is the finished install and my door keeper.
I used a cutting board I found at Costco. It fits tight around the refer door handles and the frige door is blocked as the tool hinges on the handle attachment point and tries to push at the part of the tool with the lift hole. simple and easy. Check out my kick plate. the install went way good. we tested the door lock with Tim at the wheel. He drives like a cop so it works good. Gregory O'Connor 2001 LXi43ss Romoland California 92585 951-830-5997 Rainbowrv.com |
1 user Likes GregOConnor's post |
09-15-2014, 11:33
RE: Samsung refer simple door lock
Clever, simple, fast, and the kick plate is very Art Deco! Nicely done!
