bird wont start
07-17-2005, 16:09
bird wont start
Hi All Uncle nick here sorry i didnt spell out my problem better.Lets
try again when you turn the key on it clicks seem to have plenty of
battery power-shooting sparks at the starter relay when turning the key
to start.Had a friend check the starter area and he saw sparks when
trying to start.Gotta begin somewhere so where can i get a starter
relay any auto parts place or fabic cat. etc.Any information will be
appreciated.Nick Gougeon proud owner of (Empty Pockets)84 fc coach
07-17-2005, 16:18
bird wont start
If there are sparks next to the starter then you need to clean and
reconnect the ground from the starter to the frame on both ends,
tom
1982 FC35
Vernon Center,NY
07-17-2005, 23:37
bird wont start
Hi Uncle Nick,
Got Sparks, got voltage from the ignition start circuit.
Loose wire?, Loose starter? Where did the sparks originate?, check
this first.
Before buying a relay, or, starter, have the friend use a screwdriver
and short the small connector to the large, if solenoid and starter
are good, she should start, ignition on that is. The small connector
energizes the relay, the large supplies the starter from the battery.
Mine would not start one time, I did this prroceedure. Problem was
I "did not" have the shifter in neutral. I just smacked my forehead
with the palm of my hand and said, que paso stupido!
Bob Janes, 77 FC31
--- In WanderlodgeForum@yahoogroups.com, "Nelson Gougeon"
better.Lets
key
be
07-18-2005, 01:50
bird wont start
Nick,
If you are getting sparks at the starter relay, I dare say that you
have a loose connection. There should be no sparks at all. Check all
your connections for tightness. No an uncommon problem.
George Lowry
'95 WBDA 4203
Spearfish, SD
> Yahoo! Groups Links
07-18-2005, 04:50
bird wont start
-I had a similar problem with my PT 40 and found it was nothing more
than a poor strater ground. Blue Bird has the nasty habit of
grounding to the frame and not strait back to the battery and the
ground lifts after a time. it is a shot in the dark but worth a try
Harv-- 84 pT40
In WanderlodgeForum@yahoogroups.com, George Lowry
> Nick,
you
all
> George Lowry
> '95 WBDA 4203
> Spearfish, SD
better.Lets
of
the key
when
starter
will be
coach
> > Yahoo! Groups Links
07-23-2005, 05:11
bird wont start
Hi All Uncle nick back again thanks for the information on my
starting problem it was a short at the starter fairly cheap operation
but hard to get to.thanks again Nick Gougeon proud owner of Empty
Pockets 35' 1984 fc coach.
