					CAT 3208 89SP --- anyone replaced OIL TEMP sender, what's location?
					06-03-2010, 06:45
				 Post: #1 | |||
					I need to replace my OIL TEMP sender and gauge but dont know where the sender is located>> anyone know the location of sender? Are the threads 1/4" or 1/2"? How do you get to the dash gauges to replace one? I have never been behind there. Thanks in advance Ed Gardels 89SP Arlington, Texas | |||
					06-03-2010, 13:33
				 Post: #2 | |||
					On our Cat 300 HP  the sensor is near the rear side of the oil cooler, it has one wire. Vee Three now owns teleflex, What ever gage get a match set gage & sensor, the sensor usually comes with bushings to adapt to 1/2. 1/4 or 3/8 Try the trouble shooting guide. http://www.v3instruments.com/technical.html Bill 1988 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "wl89spman" > > I need to replace my OIL TEMP sender and gauge but dont know where the sender is located>> anyone know the location of sender? Are the threads 1/4" or 1/2"? How do you get to the dash gauges to replace one? I have never been behind there. > Thanks in advance > Ed Gardels 89SP > Arlington, Texas > | |||
					06-03-2010, 13:48
				 Post: #3 | |||
| CAT 3208 89SP --- anyone replaced OIL TEMP sender, what's location? Hi Ed The back of the dash is accessable by removing the multitude of phillips head screws around the edges of the dash. Gently lift the dash up and you will be able to see what you need to do to get to the gauges.I would recommend you shut off your 12 volt power before hand. Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge WLWB41 | |||
 Member Funded
Member Funded Link Directory
User Locations Gallery
Gallery Calendar
