Suspension not filling up...??? Tag pressure not going up???
01-19-2009, 04:31
Just in case you hadn't thought about it, but when was the last time the air-dryer was serviced. The recommended service interval is 2 years* (perhaps a longer interval is OK for an RV) as thedesiccantdoes lose effectiveness over time.
And, as suggested, only a small bit of water can cause problems throughout the system. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 (For Sale) El Sobrante CA "aeonix1@mac.com" On Jan 19, 2009, at 8:18 AM, pattypape wrote:
01-19-2009, 05:18
the electric over air three valve block under the front pannel is
not the 'valve that dump the air'. the little 3valveBlock are the valves that 'signals the air to-be dumped' at the axles. the dump valve are at the axles but triggered by air from the 3 valveblock out above the front bumper. The reason you need full tank pressure prior to a dash switch command is because the low volumn lines that run from this 3valve control back to the axle will gate open but not have the psi strenth to make the dump valve at the axle switch from one position to the other. the 3 block valve is electric over air meaning an electric command is moving an air valve. between the 3 block switch and the dash is a relay, switch and a fuse. The fuse power that relays +12v input and a dash switch signal the relay to send that fused +12v power to the 3valveBlock. (not shure if there is two relays one for open and one for closed or how that dump fill signal works?) There is also a diode on my 94pt that will not let a "Dump Tag" dash command dump the other two axles but will let the "total suspension dump" command drop all 3 axles. diode acts kind like a electric current backflow valve JimR, What size hammer worked?..removing all 12v signal from the valve and re-air the main tank worked for me. I have 32 of these valves on an antilock 30,000lb 2002 equipment trailer. Passing an antilock trailer you may notice a green light midway. when glowing it alerts the driver (and CHP)that there is an antilock system failure. Gregory O'Connor of'Tim&Greg 94ptca one more day then off to Q --- In WanderlodgeForum@yahoogroups.com, jim riordan wrote: > > I had many problems with this. When you flip the tag axle switch do you hear a rush of air?? On my wbwl when you remove the front panell covering the electric in the center od the coach there are three valves (forgot the name) they some times got stuck so the tag would not fill. flip the switch ah tap on there valves. I ended up replacing them and solved the problem > > Jim Riordan > 88 WBWL XXV > Stuart, Fl > 772-260-1328 > > t3brian > Hello...All... as always I greatley appreciate any assistance from the > group... > > I am getting ready to make the journey to the Q-ralley and I went to > drive our 84 PT-40 for a quick trip and I cannot get the suspension to > fill.... > > The front & rear pressure reads 75 pounds but the tag pressure is > zero..... > > I have filpped both dump switches repeatedly but no change.... > > any suggestions???? > |
01-20-2009, 00:27
Check to be sure you have closed the water tank blow down if this valve is open system pressure will be 75 PSI
RE -------------- Original message from jim riordan |
