water purge switch
10-19-2008, 10:45
water purge switch
I am having a problem with the water purge air switch. I used the
system to purge the water last April on the way home to Michigan. I
started the coach last week and I am finding the air is coming from the
plumbing the system does not have any water at this time.
Does anyone have any suggest how to go about fixing this problem?
Hisham Amaral
97 WLWB 43'
W. Bloomfield MI.
248-932-0131
10-19-2008, 11:04
water purge switch
If yours is similar to mine there is an air regulator and a check valve in the air purge system attached to the top of the water purifier. If the check valve is bad air can get from the aux system to the water system and visa versa. You do not want water in the aux air system so shut the water system off until you identify the problem. Mine is under the bed. I have added a ball valve to prevent this problem. The system is a nice idea but a poor design. You may have another similar valve near the water heater??? There are several threads in the archives regarding this issue.
You may just have a bad purge air switch but should look at the rest of the system for sure.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
Royale Conversion
--- On Sun, 10/19/08, Hisham Amaral wrote:
Subject: [WanderlodgeForum] water purge switch
Date: Sunday, October 19, 2008, 6:45 PM
Hisham Amaral
97 WLWB 43'
W. Bloomfield MI.
248-932-0131
Do You Yahoo!?
http://mail.yahoo.com
