A/C problems
08-06-2008, 01:47
A/C problems
Ok, Problem 1 is found and corrected. I just traced the Shorepower until it
quit. Found a faulty contactor in the driver side bay with the transfer switch. I guess the contactor is a fail safe so that you don't have power fed backwards through the powercord when the genny is running. Anyways, replaced it, and now i have shorepower!! Still having a problem with one of the inverters, but Ralph is helping me step through that problem. Thanks again everyone!! Corey --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" wrote: > > Corey, below are hints to the repair found in your last post (in > this order). > ..................... > --- In WanderlodgeForum@yahoogroups.com, "coreyg67" > wrote: > > some sort > >(again I'm not an electrician and have no clue what i'm looking at) > >I don't know , > >or what > > I'm assuming > >but > >I don't know what exactly it is. > > Thanks again for all the help everyone! > > > > Corey and Jenni > > 1996 PT42' > > Prosper, TX 75078 > > > ........................................... > some times the better mechanic realize the repair is not in the > abilities oh his many talents and defers the task to those with > > GregoryO'Connor > 94ptRomolandCA > |
