cool a matic fan
06-04-2007, 08:27
Post: #21
cool a matic fan
They only give the no-load rating of 2amps. Check your original motor
in case it is different from mine. My original motor was 3 and 1/8" in diam. and the new one is 3". The shaft diameter is 5/16ths with a flat for the blade setscrew. Other than adding shims to the 3 point band mount on the motor, the only thing to be concerned about is that you have the rotation direction right. The motor is reversible. Surpluscenter part # is 10-1639. Chuck Harrison Akron, Ohio 90SP36 dgeForum@yahoogroups.com, erniecarpet@... wrote: > > Thanks, Chuck- what hp is your motor? > > Ernie Ekberg > 83PT40 > Livingston, Mt > > > > > ************************************** See what's free at http://www.aol.com. > > > [Non-text portions of this message have been removed] > |
