Solar panel for FC
03-31-2007, 12:51
Solar panel for FC
I would like to install a solar charger on my FC and am looking for
suggestions on which model to buy, where to mount the panel, and how to run the wiring down from the roof. Anyone install one on their FC? Scott Forman 82 FC35RB Memphis |
03-31-2007, 13:25
Solar panel for FC
Iwould run the wiring down the fridge vent its a straight from top to
bottom on its close the the bin with the chargers Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > I would like to install a solar charger on my FC and am looking for > suggestions on which model to buy, where to mount the panel, and how to > run the wiring down from the roof. Anyone install one on their FC? > > Scott Forman > 82 FC35RB > Memphis > |
03-31-2007, 15:11
Solar panel for FC
Got two biguns on the roof, 20" X 48" wires down the refer chimney to controller
in side compartment with inverter and 4 AGMs. Mike Hohnstein Germantown, WI 83FC35 rear bath ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Saturday, March 31, 2007 6:51 PM Subject: [WanderlodgeForum] Solar panel for FC I would like to install a solar charger on my FC and am looking for suggestions on which model to buy, where to mount the panel, and how to run the wiring down from the roof. Anyone install one on their FC? Scott Forman 82 FC35RB Memphis [Non-text portions of this message have been removed] |
03-31-2007, 16:28
Solar panel for FC
I am running off of memory here as I sold this coach to Dave Beatty.
On my then 83 FC35 with a 120 Watt solar panel, the cable was drilled down through roof at the very front, behind the front overhead. A remote display panel was installed in the front overhead. The cable then ran down the driver side far front left channel at the windshield, which led down very near the front left battery location. This worked out very well. From the drivers seat, or while seated in the front salon, the solar remote display panel was clearly visible. It was also the most direct feed to the FC battery bank at front left. Dan now 94 BB BMC 37' NM --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > I would like to install a solar charger on my FC and am looking for > suggestions on which model to buy, where to mount the panel, and how to > run the wiring down from the roof. Anyone install one on their FC? > > Scott Forman > 82 FC35RB > Memphis > |
03-31-2007, 16:28
Solar panel for FC
What brand did you use?
--- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Got two biguns on the roof, 20" X 48" wires down the refer chimney to controller in side compartment with inverter and 4 AGMs. > Mike Hohnstein > Germantown, WI > 83FC35 rear bath > ----- Original Message ----- > From: Scott Forman > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, March 31, 2007 6:51 PM > Subject: [WanderlodgeForum] Solar panel for FC > > > I would like to install a solar charger on my FC and am looking for > suggestions on which model to buy, where to mount the panel, and how to > run the wiring down from the roof. Anyone install one on their FC? > > Scott Forman > 82 FC35RB > Memphis > > > > > > [Non-text portions of this message have been removed] > |
03-31-2007, 16:38
Solar panel for FC
Evergreen
MH ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Saturday, March 31, 2007 10:28 PM Subject: [WanderlodgeForum] Re: Solar panel for FC What brand did you use? --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Got two biguns on the roof, 20" X 48" wires down the refer chimney to controller in side compartment with inverter and 4 AGMs. > Mike Hohnstein > Germantown, WI > 83FC35 rear bath > ----- Original Message ----- > From: Scott Forman > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, March 31, 2007 6:51 PM > Subject: [WanderlodgeForum] Solar panel for FC > > > I would like to install a solar charger on my FC and am looking for > suggestions on which model to buy, where to mount the panel, and how to > run the wiring down from the roof. Anyone install one on their FC? > > Scott Forman > 82 FC35RB > Memphis > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
