Cleaning Undercarriage
08-23-2006, 10:32
Replaced the old, transmission cooler hoses that had developed some weeps and
want to clean oil film off of engine, retarder, etc. I note from the retarder manual that use of high pressure water is OK to clean. Anyone got any idea of an upper limit on cleaning pressure. I've got a portable gas powered pressure sprayer but don't want to damage anything in the process. Eric in San Antonio 84FC35SBWL2 |
08-23-2006, 11:29
Eric:
For what it's worth this is what I do. Spray the areas with Simple Green concentrated spray. Let it work for 15 minutes then run a 2000PSI power washer at half RPM and wash er down. I then use air to blow off excess water. I clean up with towels from a Box of Rags(paper) available at most Ace hardware stores. Use touch up paint as required if you chose. Leroy Eckert 1990 WB 40 Niceville, FL ----- Original Message ----- From: Eric Johnson To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, August 23, 2006 5:32 PM Subject: [WanderlodgeForum] Cleaning Undercarriage Replaced the old, transmission cooler hoses that had developed some weeps and want to clean oil film off of engine, retarder, etc. I note from the retarder manual that use of high pressure water is OK to clean. Anyone got any idea of an upper limit on cleaning pressure. I've got a portable gas powered pressure sprayer but don't want to damage anything in the process. Eric in San Antonio 84FC35SBWL2 [Non-text portions of this message have been removed] |
