Leveling Jack Fluid
05-08-2006, 05:21
Leveling Jack Fluid
Can someone verify for me that I should use Auto Transmission Fluid
for the HWH leveling jacks? Any special type? Thanks. Phil Olson 83FC35SB Appleton, WI |
05-08-2006, 05:50
Leveling Jack Fluid
Phil I have a 94 and the manual says to use quote "universal, multipurpose
or Dexron transmission fluid. DO NOT USE brake fluid or hydraulic jack fluid. Use of these fluids can damage seal." unquote On 5/8/06, olson_phil > > Can someone verify for me that I should use Auto Transmission Fluid > for the HWH leveling jacks? Any special type? > Thanks. > Phil Olson > 83FC35SB > Appleton, WI > > > > > > > > Yahoo! Groups Links > > > > > > > [Non-text portions of this message have been removed] |
05-08-2006, 05:53
Leveling Jack Fluid
The red stuff, Dextron II or Dextron III
Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "olson_phil" > > Can someone verify for me that I should use Auto Transmission Fluid > for the HWH leveling jacks? Any special type? > Thanks. > Phil Olson > 83FC35SB > Appleton, WI > |
