Temperature sensor thread size
04-30-2006, 11:40
I fired up the bus today and the engine coolant temperature gauge went up to
240F almost immediately. I shut down the bus and found that the oil was still cold as were the radiator and the hoses. I tested the sensor wire from the gauge to the sender and seems to be ok. The gauge seems to be alright so I think I will swap out the sender next, it was also cool to the touch. The gauge is a Teleflex unit and the senders seem to be available at most marine supply stores; I just didn't check what pipe thread size it was. Any help would be appreciated. Tim Hannink Winter Park, FL 1981 FC-33SB --------------------------------- Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ countries) for 2¢/min or less. [Non-text portions of this message have been removed] |
