					Oil changes
					04-23-2006, 02:48
				Oil changes
					I'll be changing the oil in my 3208 in the near future.  I'm thinking
			that the oil pan I use on my other vehicles is probably not large enough to capture the full amount of oil in the 3208. How do other people deal with this problem? Have a second container ready to push in place, reinstall the plug and start over, or buy a larger container? Ideas? Kerry 82 FC 35 Denver  |
					04-23-2006, 02:57
				Oil changes
					5 gallon bucket works good.
			Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 02:48 PM 4/23/2006 +0000, you wrote: >I'll be changing the oil in my 3208 in the near future. I'm thinking >that the oil pan I use on my other vehicles is probably not large >enough to capture the full amount of oil in the 3208. How do other >people deal with this problem? Have a second container ready to push >in place, reinstall the plug and start over, or buy a larger >container? Ideas? > >Kerry >82 FC 35 >Denver > > >  |
					04-23-2006, 03:01
				Oil changes
					Kerry,
			Got mine at Advance Auto Parts.. Holds 15 Qts.. Drained the whole thing in room to spare.. $7.00 Stephen 81 FC-33SB Plant City, FL _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of davidkerryedwards Sent: Sunday, April 23, 2006 10:48 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Oil changes I'll be changing the oil in my 3208 in the near future. I'm thinking that the oil pan I use on my other vehicles is probably not large enough to capture the full amount of oil in the 3208. How do other people deal with this problem? Have a second container ready to push in place, reinstall the plug and start over, or buy a larger container? Ideas? Kerry 82 FC 35 Denver _____ YAHOO! GROUPS LINKS * Visit your group "WanderlodgeForum <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. _____ [Non-text portions of this message have been removed]  |
					04-23-2006, 03:22
				Oil changes
					Kerry,
			Buy a large pan. I went overkill on my drain system...I bought a rectangle 9 gal. tank, added a 4" inspection fitting/cover, added a drain spicket, mounted it on a low profile frame/wheel cart. I remove the cover, roll the unit under the drain plug, remove the drain plug, replace the drain plug and tank cover after the oil has drained, roll the unit out from under the bus...no mess. Fill the engine as needed. Set the tank up on my bench. Open the spicket and refill the gallon oil jugs...again, no mess. Like I said, OVERKILL...works great. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. >  |
					04-23-2006, 11:07
				Oil changes
					--David, I bought a plastic container from wally world that could hold 15-16
			gals. Works great, only use it once a year. Dale '97wb41' Adventure Bird Pinckney, Mi.  |
