Carpet Wet
04-22-2006, 00:44
Carpet Wet
My 1985 FC 35 Developed some klind of water leak . Carpet soaked from
the fridge to the hot water switch.Looked into the water tank area all
seems dry. Before I start taking things apart any info available.
Thanks in advance to all for your help.
Mario 1985 FC 35
04-22-2006, 01:21
Carpet Wet
Mario:
Remove the kick plate under the last closet. The water tank extends under
the closet behind that area. There is an indenture in the tank at that
point and has been known to develop a split or crack
in that area. Does it only leak when the tank is full? but not when 1/2
full? Also like Ernie mentioned, check the fittings from the water pump
under the sink back to the tank.
Safe travels,
> Mario 1985 FC 35
04-22-2006, 01:27
Carpet Wet
Did you check under the kitchen sink, in my '83 that is where the
water pump is located. Where do you live? could it be a burst pipe
caused by freezing pipes? It's not a problem here in florida, but
elsewhere it's a big deal. There is also an access panel under the
fridge.
Thanks
Bruce
'83FCSB
from
all
> Mario 1985 FC 35
04-24-2006, 00:30
Carpet Wet
Icemakers are a common leaker, regardless of whether it's on or
off. The water supply hookup behind the grill is a garden hose type
and can use a new washer on occasion.
A leak can often manifest itself a long ways from the source.
Good Luck,
Gary Miller
83 FC 33
Milwaukee area
from
all
> Mario 1985 FC 35
