8V-92 Exhust manifold
03-18-2006, 11:22
Hi All, Carol and I are back in Illinois after wintering at SPI. We
had a good winter and all went well. On the way home we started hearing a little clatter in the exhust system. On further inspection I found the left exhust manifold cracked. We're wondering if anyone has a good source for one of theses? We also had one time when the refrigerator would now lite on gas, I pulled the outside cover off the gas section and discovered a carbon build up on the igniter and thermocouple, cleaned it off (scraped with a screw driver) and it's worked great since. ..Bob&Carol...93pt40 8v92-500hp Illinois |
03-19-2006, 12:23
Hi Bob, good to hear from you. Will you be going to Montana this summer?
Ernie-83pt40 in Texas with rain!! -----Original Message----- From: Bob & Carol Howald` To: WanderlodgeForum@yahoogroups.com Sent: Sat, 18 Mar 2006 23:22:16 -0000 Subject: [WanderlodgeForum] 8V-92 Exhust manifold Hi All, Carol and I are back in Illinois after wintering at SPI. We had a good winter and all went well. On the way home we started hearing a little clatter in the exhust system. On further inspection I found the left exhust manifold cracked. We're wondering if anyone has a good source for one of theses? We also had one time when the refrigerator would now lite on gas, I pulled the outside cover off the gas section and discovered a carbon build up on the igniter and thermocouple, cleaned it off (scraped with a screw driver) and it's worked great since. ..Bob&Carol...93pt40 8v92-500hp Illinois Yahoo! Groups Links [Non-text portions of this message have been removed] |
03-20-2006, 02:58
> > Hi Bob, good to hear from you. Will you be going to Montana this summer? Ernie-83pt40 in Texas with rain!! > Thanks Ernie, We did not have much time to spend in Springtown this time on the way back, maybe next time we'll get together. Leaving on the 3rd of April for Jackson Hole, we bought a snow-cat and want to take that out to the property. Hope to play in the snow for a while.... send ma an e-mail as I can't find your's...regard's..Bob&Carol |
