Hot water heater troubleshooting
09-30-2005, 16:39
The engine heats the water, but turning on the breaker after parking
does not result in hot water. I am getting ready to start looking for
the problem. Any suggestions of things to check and in what order,
would be appreciated. Thanks, JB Lewis, 77FC31, Grand Lake,Ok.
09-30-2005, 23:39
ck for elec at the probes..like a regular heater at home..if you have
power then you have a element burnt out!~
if not thermosat or breaker pop-ed?
woody 81fcrb
--- In WanderlodgeForum@yahoogroups.com, "bascom1968"
> would be appreciated. Thanks, JB Lewis, 77FC31, Grand Lake,Ok.ker
10-01-2005, 01:27
There is also a safety device that will not allow the heater to go on
if the water is to low in the tank.
tom
1982 FC35
Vernon Center,NY
>woody 81fcrb
>YAHOO! GROUPS LINKS
> * Visit your group
Wanderl\
10-01-2005, 13:03
make sure breaker is on, switch is red (on) on the back of the heater
is a cover held on with two screws, kill power take them out you will
see thermostat on the bottom, be careful with power on,check for
voltage at the top screw, if voltage present at top screw but not
bottom, elememt is shot. if not back up to thermostat or eco switch
all should pass votage to element. bb sells for 28.00 at home depot
they have an adaper that will adapt from the 4 hole flange into a
screw in type elemnet adapter and element is about $15.00. orr and orr
sells a 4 bolt elemnt for about $9.50
re brake
for
10-01-2005, 15:55
Found the problem. An unmarked wall switch in the bedroom controls the
tank! Happy to find this before tearing the tank apart. Thanks for
suggestions.
