Belts & propane furnace
10-17-2010, 02:40
Is there any way to tighten engine belts without removing
the back bumper to swing the radiator out on my 90 SP36?
Also, just returned from a chilly trip where only the front propane
furnace worked. The rear elec heater and rear propane furnace do
not although the elec heater in the bathroom does. The schematic
I have refers to a Primus furnace but I don't have a Primus.
William C Harrison
Akron, Ohio
90 WLSP36
10-17-2010, 15:39
I don't think there is a good way to tighten the belts without swinging the rad.  Keep a good check on you belts as if you have any trouble on the road it can cost you a lot more than in your driveway or local shop. Don't ask me how I know that/////   Four bolts in the bumper & two in the rad. It is not bad to swing the rad. I do mine at least once a year.  If you want give me your phone number & I'll give you a call.        Don
On Sun, Oct 17, 2010 at 10:40 AM, williamcharrison <"williamcharrison@yahoo.com"> wrote:
William C Harrison
Akron, Ohio
90 WLSP36
