SP36 Alternator Schematic
08-12-2009, 02:34
Does anyone have an alternator schematic for this unit? The alternator is
supposedly putting out a charge, but it isn't charging the batteries.
Thanks,
Dan Mahoney
1991 SP36
Bloomfield, MI
08-13-2009, 14:32
> Thanks,
> Dan Mahoney
> 1991 SP36
> Bloomfield, MI
I assume you checked the voltage at the isolater located in the coach battery
compartment. Mine went bad and had to be replaced.
Bob Criss
Bethel Park, PA
90 SP36
08-13-2009, 16:32
Hi  Bob    Did you ever figure out how to keep your engine compartment any cooler & your fan from coming on as often?
Don Spithaler
89 SP 36'
Butler, PA               On the road in Rapid City, SD
"WanderlodgeForum%40yahoogroups.com"
I assume you checked the voltage at the isolater located in the coach battery compartment. Mine went bad and had to be replaced.
Bob Criss
Bethel Park, PA
90 SP36
08-14-2009, 03:35
--- In WanderlodgeForum@yahoogroups.com, Donald Spithaler
> Don Spithaler
> 89 SP 36'
> Butler, PA
Hi Don.
Hope you are having a good time in SD.
I found, as mentioned in previous posting, that my oil cooler had leaked oil
into the cooling system. A big mess. I still have the sooling system
conditioner/cleaner in the coach so I don't know if the heating problen causing
the frequent cycling of the fan is solved or not. I expect not. I had a long
discussion with the folks at Caterpillar who installed both the new engine and
the new radiator. The solution has not been found in spite of the installation
of a 16" electric thermostat controlled fan to help the mechanical one. It
still cycles more often than the old rad with old engine. This is on-going but
I am almost certain now that the rad is the culprit. I will let you know when
the problem is solved.
Have a safe trip.
Bob Criss
Bethel Park, PA
90 SP36
> > Bob Criss
> > Bethel Park, PA
> > 90 SP36
08-15-2009, 03:49
The radiator shrouding is important to match up and reinstall properly plus fan
speed and clutch performance is important too. If I had a 3208 I would
definitely find a two speed aftermarket fan that would work. It may cycle more
often becaue the t stat was shadetree engineered????
In an old 3208 dumptruck I would always try and manually engage my fan at low
rpm when the temp gauge clued me of a soon to clutch-up event. I didnt want the
belt and bearing to experience a 2800 rpm abrupt torque-kick. with the two
speed you could shade-tree engineer a t stat to turn it on at a lower temp and
may never have it go to high speed??.
I have this fan clutch on a 92 N-14. I think this will solve many 3208 issues.
http://www.youtube.com/watch?v=5MU7jNs0WM8
Greg OfTim&Greg
94ptca
> Hi Don.
> Have a safe trip.
> Bob Criss
> Bethel Park, PA
> 90 SP36
> > > Bob Criss
> > > Bethel Park, PA
> > > 90 SP36
