remodel
06-23-2009, 11:49
remodel
Is anyone out there familiar with what is under the bed in the rear. I want to
remove the standard bed that came with the bluebird and replace it with a smaller bed that would be bolted to the floor. Ultimately I need it to be a flat surface and want to know if this is possible to achieve. It is an 88 wanderlodge. Thanks in advance for any guinine knowledge on the issue. Patty |
06-23-2009, 17:22
remodel
Patty
Be a little more specific What model BB ? Year ? Mario 1985 fc 35 --- In WanderlodgeForum@yahoogroups.com, "patty_austin" > > Is anyone out there familiar with what is under the bed in the rear. I want to remove the standard bed that came with the bluebird and replace it with a smaller bed that would be bolted to the floor. Ultimately I need it to be a flat surface and want to know if this is possible to achieve. It is an 88 wanderlodge. Thanks in advance for any guinine knowledge on the issue. Patty > |
06-24-2009, 01:21
remodel
Do you have a walkaround bed or is it a bed that goes from side to side (Drivers
side to pass. side)? Bob Lawrence 84 PT36 Ft. DeSoto, Fla Is anyone out there familiar with what is under the bed in the rear. I want to remove the standard bed that came with the bluebird and replace it with a smaller bed that would be bolted to the floor. Ultimately I need it to be a flat surface and want to know if this is possible to achieve. It is an 88 wanderlodge. Thanks in advance for any guinine knowledge on the issue. Patty > |
06-24-2009, 07:34
remodel
Assuming it is a forward facing island queen bed, there should be a 116 gallon
water tank, a water pump and filter, and an access hatch to the top of the engine, so finding a new place for the fresh water system would be a challenge. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "patty_austin" > > Is anyone out there familiar with what is under the bed in the rear. I want to remove the standard bed that came with the bluebird and replace it with a smaller bed that would be bolted to the floor. Ultimately I need it to be a flat surface and want to know if this is possible to achieve. It is an 88 wanderlodge. Thanks in advance for any guinine knowledge on the issue. Patty > |
