FYI
09-17-2008, 16:22
FYI
I have an 82 fc 35 with 3208 cat. After my last trip, it was running
real rough at idle then quit and it wouldn't start again. I noticed the Racor guage was near the red (low fuel flow). So I replace all fuel filters including the Racor, filled the racor bowl with fuel and bled the injectors. It started and ran ok for a few minutes then started the same thing. The racor filter bowl was dry. Then I remembered about an electric lift fuel pump mounted near the fuel tank in the rear. I checked for voltage with ignition on and there was 12 volts. I replaced the pump. Not an easy job lying under the coach with very little room to move. As soon as turned on the ignition it started pumping, filled the filter, I bled the injectors and all is well. Jim Marsh 82fc 35 Serendipity |
01-21-2010, 06:05
FYI
Neighbor just called...he saw an older yellow/beige 'Bird with bright green foreign toad heading out of town on the 91 fwy in Anaheim, CA...got to be Lucas & Linda.
ÃÂ Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA |
01-21-2010, 06:11
FYI
Good to know Curt. Now we just have to get him in here and parked safe
2010/1/21 Curt Sprenger <"curtsprenger@gmail.com">
-- Rob, Sue and Joey Robinson 94 WLWB |
01-21-2010, 09:28
FYI
Hi Curt
Should be leaving for Q Friday morning . Save me a spot . Great to be back on the west coast the weather is still better . mario 1985fc35 carlsbad ca. --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Neighbor just called...he saw an older yellow/beige 'Bird with bright green > foreign toad heading out of town on the 91 fwy in Anaheim, CA...got to be > Lucas & Linda. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > |
01-21-2010, 09:43
FYI
Mario
Awaiting your arrival here@ tha Q pond!!
This moisture is very welcome to us desert folks, but disappointing to the majority.
Hope you have a safe trip.
Fred & Jeanne Hulse
Morristown,Arizona 1997 Wanderlodge WB41 |
01-21-2010, 09:54
FYI
01-21-2010, 15:34
FYI
Don'[t know if we can bring any sunshine but we might bring some snow.
Jim and Linda Marsh 97 wlwb 41. --- In WanderlodgeForum@yahoogroups.com, Ernie Ekberg > > Mario- bring some sunshine > Ernie- me and the girls are watching the river in front of the bus at Q > > > Ernie Ekberg > 83PT40 > Wanderlodge > Weatherford, Txà 817-475-3991 > http://www.ernieekbergflooring.net > > --- On Thu, 1/21/10, mariopatti1 > > > From: mariopatti1 > Subject: [WanderlodgeForum] Re: FYI > To: WanderlodgeForum@yahoogroups.com > Date: Thursday, January 21, 2010, 3:28 PM > > > à > > > > Hi Curt > Should be leaving for Q Friday morning . Save me a spot . Great to be back on the west coast the weather is still better . > mario 1985fc35 carlsbad ca. > > --- In WanderlodgeForum@ yahoogroups. com, Curt Sprenger wrote: > > > > Neighbor just called...he saw an older yellow/beige 'Bird with bright green > > foreign toad heading out of town on the 91 fwy in Anaheim, CA...got to be > > Lucas & Linda. > > > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > |
