PT Radiator Air Scoop
09-11-2008, 04:40
Post: #21
I hope you guys do the ribbon thing, kinda why I didnt post my
result. I found that there is no airflow past the grill. the ribbon would not lift horiz. mounted on aprox 6 inch a piece of plastic, the ribbon would spin out and back to the rear. when the fan come on the ribbon got sucked to the grill. I wanted to open the rear gate and see if that changed air flow. But remember;is you only need the engine oil to be 230 to 250 and the water 180 to 195 to make the bus run as engineered. running cooler than that is not cool. I do think that the hydrolic fan could do a better job of reusing the radiator passed air to more evenly cool the outside of the block. If you run the bus at 1500 rpm standing still ;fan on. most of the air goes out the first 3 feet of the rear door vent and verry little ever gets pathed to the battery area and manifold over the passanger side engine block. I wonder if closing off most of the leading part of the rear door vent would shroud the air to push heat out of the engine compartment. I would think it would path air thru the rad for those who have electric fans above the batteies. shrouding engines for air cooling is an engineered calc. I think that is where the gas workhorse pushers are having problems. GregoryO'Connor 94ptRomoladCa --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > > Gregg...... > > Do I need to add Air Louvers like on the Eagle, rotate the grill 45 > degrees, Do I have to tie ribbons on the grill and go for a drive???? > Come on cough it up........ > > Kurt Horvath > 95 PT-42 > 10AC > > --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > > > > Hey Greg...I'll believe anything ..until I won't... Please fill us > in. > > > > We are hanging... > > > > On Wed, Sep 10, 2008 at 3:26 PM, Scott Forman > <scottforman75@>wrote: > > > > > You can't leave us hanging like that. > > > > > > Scott Forman > > > 86 PT38 > > > Memphis > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > "Gregory OConnor" > > > > > > > > > > > > > > > I tied ribbons in my grill last week and taped a piece of erect > > > flat > > > > plastic pointed outward at drivers window and grill to get a > clue on > > > > air flow. wont comment because you guys wont believe it. > > > > > > > > > > > > > > > > > > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > |
09-11-2008, 05:32
Post: #22
> > I hope you guys do the ribbon thing, kinda why I didnt post my > result. > > I found that there is no airflow past the grill. the ribbon would > not lift horiz. mounted on aprox 6 inch a piece of plastic, the > ribbon would spin out and back to the rear. when the fan come on the > ribbon got sucked to the grill. I wanted to open the rear gate and > see if that changed air flow. But remember;is you only need the > engine oil to be 230 to 250 and the water 180 to 195 to make the bus > run as engineered. running cooler than that is not cool. > > I do think that the hydrolic fan could do a better job of reusing > the radiator passed air to more evenly cool the outside of the > block. If you run the bus at 1500 rpm standing still ;fan on. most > of the air goes out the first 3 feet of the rear door vent and > verry little ever gets pathed to the battery area and manifold over > the passanger side engine block. I wonder if closing off most of the > leading part of the rear door vent would shroud the air to push heat > out of the engine compartment. I would think it would path air thru > the rad for those who have electric fans above the batteies. > > shrouding engines for air cooling is an engineered calc. I think > that is where the gas workhorse pushers are having problems. > GregoryO'Connor > 94ptRomoladCa > > > > --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > > > > > Gregg...... > > > > Do I need to add Air Louvers like on the Eagle, rotate the grill > 45 > > degrees, Do I have to tie ribbons on the grill and go for a > drive???? > > Come on cough it up........ > > > > Kurt Horvath > > 95 PT-42 > > 10AC > > > > --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > > > > > > > Hey Greg...I'll believe anything ..until I won't... Please fill > us > > in. > > > > > > We are hanging... > > > > > > On Wed, Sep 10, 2008 at 3:26 PM, Scott Forman > > <scottforman75@>wrote: > > > > > > > You can't leave us hanging like that. > > > > > > > > Scott Forman > > > > 86 PT38 > > > > Memphis > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > "Gregory OConnor" > > > > > > > > > > > > > > > > > > > I tied ribbons in my grill last week and taped a piece of > erect > > > > flat > > > > > plastic pointed outward at drivers window and grill to get a > > clue on > > > > > air flow. wont comment because you guys wont believe it. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, CA > > > > >I have followed with great interest the ribbon test string??. I too have constructed scoops to direct air into and through the radiator in my '90 SP36. They stick out the sides 4 inches and are painted to match. Look pretty but were of little help. I did not use the ribbon test as I have a guage that measures inches of water in both directions. When I attached a long hose to it and placed it in various positions in the rear and side grills I found NO measureable pressure. If anything the rear of the coach seems to be a calm area with very little air movement/pressure. I have yet to do the measure thing since the scoops were added. Another thought worth considering is to install 12 volt cooling fans on the side grills to suck air into and out through the radiator. As you can tell I am trying to limit the amount the fan runs. I did install a 180 deg. diverter (thermostat) in my 3208 but have not taken it out with that change yet. Here's hoping! Bob Criss '90 SP36 Bethel Park, PA > |
09-11-2008, 07:57
Post: #23
While this discussion has been going on I have been looking for an article I read about rear engine vehicles. Cooling was a concern because there is no way to get any "ram" air effect. The only radiator placement that had any benefit was rear mounted. There is a negative pressure immediately following a vehicle and there can be some passive air flow through a rear mounted radiator. It was not enough to "idle" the fan. I will keep looking, maybe I can find it yet. It did include wind tunnel tests.
- Chuck Wheeler-
FC 31SB Fort Worth TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of crissrace Sent: Thursday, September 11, 2008 12:33 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: PT Radiator Air Scoop --- In "WanderlodgeForum%40yahoogroups.com", "Gregory OConnor" > > I hope you guys do the ribbon thing, kinda why I didnt post my > result. > > I found that there is no airflow past the grill. the ribbon would > not lift horiz. mounted on aprox 6 inch a piece of plastic, the > ribbon would spin out and back to the rear. when the fan come on the > ribbon got sucked to the grill. I wanted to open the rear gate and > see if that changed air flow. But remember;is you only need the > engine oil to be 230 to 250 and the water 180 to 195 to make the bus > run as engineered. running cooler than that is not cool. > > I do think that the hydrolic fan could do a better job of reusing > the radiator passed air to more evenly cool the outside of the > block. If you run the bus at 1500 rpm standing still ;fan on. most > of the air goes out the first 3 feet of the rear door vent and > verry little ever gets pathed to the battery area and manifold over > the passanger side engine block. I wonder if closing off most of the > leading part of the rear door vent would shroud the air to push heat > out of the engine compartment. I would think it would path air thru > the rad for those who have electric fans above the batteies. > > shrouding engines for air cooling is an engineered calc. I think > that is where the gas workhorse pushers are having problems. > GregoryO'Connor > 94ptRomoladCa > > > > --- In "WanderlodgeForum%40yahoogroups.com", "Kurt Horvath" > > > > > Gregg...... > > > > Do I need to add Air Louvers like on the Eagle, rotate the grill > 45 > > degrees, Do I have to tie ribbons on the grill and go for a > drive???? > > Come on cough it up........ > > > > Kurt Horvath > > 95 PT-42 > > 10AC > > > > --- In "WanderlodgeForum%40yahoogroups.com", "Curt Sprenger" > > > > > > > > Hey Greg...I'll believe anything ..until I won't... Please fill > us > > in. > > > > > > We are hanging... > > > > > > On Wed, Sep 10, 2008 at 3:26 PM, Scott Forman > > <scottforman75@<WBR>>wrote: > > > > > > > You can't leave us hanging like that. > > > > > > > > Scott Forman > > > > 86 PT38 > > > > Memphis > > > > > > > > --- In "WanderlodgeForum%40yahoogroups.com" > > > > "Gregory OConnor" > > > > > > > > > > > > > > > > > > > I tied ribbons in my grill last week and taped a piece of > erect > > > > flat > > > > > plastic pointed outward at drivers window and grill to get a > > clue on > > > > > air flow. wont comment because you guys wont believe it. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, CA > > > > >I have followed with great interest the ribbon test string??. I too have constructed scoops to direct air into and through the radiator in my '90 SP36. They stick out the sides 4 inches and are painted to match. Look pretty but were of little help. I did not use the ribbon test as I have a guage that measures inches of water in both directions. When I attached a long hose to it and placed it in various positions in the rear and side grills I found NO measureable pressure. If anything the rear of the coach seems to be a calm area with very little air movement/pressure. I have yet to do the measure thing since the scoops were added. Another thought worth considering is to install 12 volt cooling fans on the side grills to suck air into and out through the radiator. As you can tell I am trying to limit the amount the fan runs. I did install a 180 deg. diverter (thermostat) in my 3208 but have not taken it out with that change yet. Here's hoping! Bob Criss '90 SP36 Bethel Park, PA > |
09-11-2008, 11:47
Post: #24
Hey BOB:
Please keep me posted on what changes u make to the radiator airflow... thanks Hank 90SP36 --- In WanderlodgeForum@yahoogroups.com, "crissrace" wrote: > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > I hope you guys do the ribbon thing, kinda why I didnt post my > > result. > > > > I found that there is no airflow past the grill. the ribbon would > > not lift horiz. mounted on aprox 6 inch a piece of plastic, the > > ribbon would spin out and back to the rear. when the fan come on > the > > ribbon got sucked to the grill. I wanted to open the rear gate and > > see if that changed air flow. But remember;is you only need the > > engine oil to be 230 to 250 and the water 180 to 195 to make the > bus > > run as engineered. running cooler than that is not cool. > > > > I do think that the hydrolic fan could do a better job of reusing > > the radiator passed air to more evenly cool the outside of the > > block. If you run the bus at 1500 rpm standing still ;fan on. most > > of the air goes out the first 3 feet of the rear door vent and > > verry little ever gets pathed to the battery area and manifold over > > the passanger side engine block. I wonder if closing off most of > the > > leading part of the rear door vent would shroud the air to push > heat > > out of the engine compartment. I would think it would path air thru > > the rad for those who have electric fans above the batteies. > > > > shrouding engines for air cooling is an engineered calc. I think > > that is where the gas workhorse pushers are having problems. > > GregoryO'Connor > > 94ptRomoladCa > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > > > > > > > > Gregg...... > > > > > > Do I need to add Air Louvers like on the Eagle, rotate the grill > > 45 > > > degrees, Do I have to tie ribbons on the grill and go for a > > drive???? > > > Come on cough it up........ > > > > > > Kurt Horvath > > > 95 PT-42 > > > 10AC > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > > > > > > > > > > Hey Greg...I'll believe anything ..until I won't... Please fill > > us > > > in. > > > > > > > > We are hanging... > > > > > > > > On Wed, Sep 10, 2008 at 3:26 PM, Scott Forman > > > <scottforman75@>wrote: > > > > > > > > > You can't leave us hanging like that. > > > > > > > > > > Scott Forman > > > > > 86 PT38 > > > > > Memphis > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > "Gregory OConnor" > > > > > > > > > > > > > > > > > > > > > > > I tied ribbons in my grill last week and taped a piece of > > erect > > > > > flat > > > > > > plastic pointed outward at drivers window and grill to get > a > > > clue on > > > > > > air flow. wont comment because you guys wont believe it. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > > Curt Sprenger > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > Anaheim Hills, CA > > > > > > >I have followed with great interest the ribbon test string??. I > too have constructed scoops to direct air into and through the > radiator in my '90 SP36. They stick out the sides 4 inches and are > painted to match. Look pretty but were of little help. I did not > use the ribbon test as I have a guage that measures inches of water > in both directions. When I attached a long hose to it and placed it > in various positions in the rear and side grills I found NO > measureable pressure. If anything the rear of the coach seems to be > a calm area with very little air movement/pressure. I have yet to > do the measure thing since the scoops were added. > Another thought worth considering is to install 12 volt cooling fans > on the side grills to suck air into and out through the radiator. As > you can tell I am trying to limit the amount the fan runs. I did > install a 180 deg. diverter (thermostat) in my 3208 but have not > taken it out with that change yet. Here's hoping! > Bob Criss > '90 SP36 > Bethel Park, PA > > > |
09-11-2008, 15:43
Post: #25
My main reason for airflow is my interest in adding a Mister. I
think the mister cools the air and not the radiator therefor you need space and time to do the calorie thing to the air. My last trip up the grapevine pulling a HummerPU in 105 degree heat and a freshly rodded radiator proved that the cooling system works proper the way BBengineeres designed it to. The mister is just a project to add a safety device for backup as there is a small variable between 'optimal operating temp' 185 and 'your totaly screwed temp' 205. I like to run the dash ac but the fan need to be on to blow air over the ac coil. It is not the added stress of the ac compressor that engineers prompt the fan to run every time the ac is on, it is the need for air over the ac coil. The prob with running the ac is I dont like to run the fan as the bus water stays at 160 and the oil way cool also. a 12 volt fan should do the trick for the ac and even be an added device to cool part of the bus rad. I wonder if some major 12v airflow over the ac coil and one 12Vfan directing that air to be exhusted over and out the grill at the driver side ; with closed off rear vents is the ticket?? I dont think I will ever do it because sill havent taken down the Christmass lights. gotta do that soon because they dont work and its a litle over 100 day to go. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > Hey BOB: > Please keep me posted on what changes u make to the radiator > airflow... thanks > Hank > 90SP36 > > > --- In WanderlodgeForum@yahoogroups.com, "crissrace" > wrote: > > > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > > > > I hope you guys do the ribbon thing, kinda why I didnt post my > > > result. > > > > > > I found that there is no airflow past the grill. the ribbon would > > > not lift horiz. mounted on aprox 6 inch a piece of plastic, the > > > ribbon would spin out and back to the rear. when the fan come on > > the > > > ribbon got sucked to the grill. I wanted to open the rear gate > and > > > see if that changed air flow. But remember;is you only need the > > > engine oil to be 230 to 250 and the water 180 to 195 to make the > > bus > > > run as engineered. running cooler than that is not cool. > > > > > > I do think that the hydrolic fan could do a better job of reusing > > > the radiator passed air to more evenly cool the outside of the > > > block. If you run the bus at 1500 rpm standing still ;fan on. > most > > > of the air goes out the first 3 feet of the rear door vent and > > > verry little ever gets pathed to the battery area and manifold > over > > > the passanger side engine block. I wonder if closing off most of > > the > > > leading part of the rear door vent would shroud the air to push > > heat > > > out of the engine compartment. I would think it would path air > thru > > > the rad for those who have electric fans above the batteies. > > > > > > shrouding engines for air cooling is an engineered calc. I think > > > that is where the gas workhorse pushers are having problems. > > > GregoryO'Connor > > > 94ptRomoladCa > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > > > > > > > > > > > Gregg...... > > > > > > > > Do I need to add Air Louvers like on the Eagle, rotate the > grill > > > 45 > > > > degrees, Do I have to tie ribbons on the grill and go for a > > > drive???? > > > > Come on cough it up........ > > > > > > > > Kurt Horvath > > > > 95 PT-42 > > > > 10AC > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > > > > > > > > > > > > > Hey Greg...I'll believe anything ..until I won't... Please > fill > > > us > > > > in. > > > > > > > > > > We are hanging... > > > > > > > > > > On Wed, Sep 10, 2008 at 3:26 PM, Scott Forman > > > > <scottforman75@>wrote: > > > > > > > > > > > You can't leave us hanging like that. > > > > > > > > > > > > Scott Forman > > > > > > 86 PT38 > > > > > > Memphis > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > "Gregory OConnor" > > > > > > > > > > > > > > > > > > > > > > > > > > > I tied ribbons in my grill last week and taped a piece of > > > erect > > > > > > flat > > > > > > > plastic pointed outward at drivers window and grill to > get > > a > > > > clue on > > > > > > > air flow. wont comment because you guys wont believe it. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > > > Curt Sprenger > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > Anaheim Hills, CA > > > > > > > > >I have followed with great interest the ribbon test string??. I > > too have constructed scoops to direct air into and through the > > radiator in my '90 SP36. They stick out the sides 4 inches and are > > painted to match. Look pretty but were of little help. I did not > > use the ribbon test as I have a guage that measures inches of water > > in both directions. When I attached a long hose to it and placed > it > > in various positions in the rear and side grills I found NO > > measureable pressure. If anything the rear of the coach seems to > be > > a calm area with very little air movement/pressure. I have yet to > > do the measure thing since the scoops were added. > > Another thought worth considering is to install 12 volt cooling > fans > > on the side grills to suck air into and out through the radiator. > As > > you can tell I am trying to limit the amount the fan runs. I did > > install a 180 deg. diverter (thermostat) in my 3208 but have not > > taken it out with that change yet. Here's hoping! > > Bob Criss > > '90 SP36 > > Bethel Park, PA > > > > > > |
09-12-2008, 16:13
Post: #26
Gregg,
http://www.acpartsguys.com/ac_supplies Check this web site, scroll down a little and look for the Hayden High Performance Rapid Cool Radiator Mist System. $50 bucks. A couple of these units with a few more nozzles would work. Mount it, wire it, good to go. If there is no vacuum to pull it in you will need to spay the water into the Rad some how. Kurt Horvath 95 PT-42 10AC --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > My main reason for airflow is my interest in adding a Mister. I > think the mister cools the air and not the radiator therefor you > need space and time to do the calorie thing to the air. My last > trip up the grapevine pulling a HummerPU in 105 degree heat and a > freshly rodded radiator proved that the cooling system works proper > the way BBengineeres designed it to. > > The mister is just a project to add a safety device for backup as > there is a small variable between 'optimal operating temp' 185 > and 'your totaly screwed temp' 205. > > I like to run the dash ac but the fan need to be on to blow air over > the ac coil. It is not the added stress of the ac compressor that > engineers prompt the fan to run every time the ac is on, it is the > need for air over the ac coil. The prob with running the ac is I > dont like to run the fan as the bus water stays at 160 and the oil > way cool also. > > a 12 volt fan should do the trick for the ac and even be an added > device to cool part of the bus rad. I wonder if some major 12v > airflow over the ac coil and one 12Vfan directing that air to be > exhusted over and out the grill at the driver side ; with closed > off rear vents is the ticket?? > > I dont think I will ever do it because sill havent taken down the > Christmass lights. gotta do that soon because they dont work and its > a litle over 100 day to go. > > GregoryO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > > > > Hey BOB: > > Please keep me posted on what changes u make to the radiator > > airflow... thanks > > Hank > > 90SP36 > > > > > > --- In WanderlodgeForum@yahoogroups.com, "crissrace" > > wrote: > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > > > > > > > I hope you guys do the ribbon thing, kinda why I didnt post my > > > > result. > > > > > > > > I found that there is no airflow past the grill. the ribbon > would > > > > not lift horiz. mounted on aprox 6 inch a piece of plastic, > the > > > > ribbon would spin out and back to the rear. when the fan come > on > > > the > > > > ribbon got sucked to the grill. I wanted to open the rear gate > > and > > > > see if that changed air flow. But remember;is you only need > the > > > > engine oil to be 230 to 250 and the water 180 to 195 to make > the > > > bus > > > > run as engineered. running cooler than that is not cool. > > > > > > > > I do think that the hydrolic fan could do a better job of > reusing > > > > the radiator passed air to more evenly cool the outside of the > > > > block. If you run the bus at 1500 rpm standing still ;fan on. > > most > > > > of the air goes out the first 3 feet of the rear door vent > and > > > > verry little ever gets pathed to the battery area and manifold > > over > > > > the passanger side engine block. I wonder if closing off most > of > > > the > > > > leading part of the rear door vent would shroud the air to > push > > > heat > > > > out of the engine compartment. I would think it would path air > > thru > > > > the rad for those who have electric fans above the batteies. > > > > > > > > shrouding engines for air cooling is an engineered calc. I > think > > > > that is where the gas workhorse pushers are having problems. > > > > GregoryO'Connor > > > > 94ptRomoladCa > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > > > > > > > > > > > > > > Gregg...... > > > > > > > > > > Do I need to add Air Louvers like on the Eagle, rotate the > > grill > > > > 45 > > > > > degrees, Do I have to tie ribbons on the grill and go for a > > > > drive???? > > > > > Come on cough it up........ > > > > > > > > > > Kurt Horvath > > > > > 95 PT-42 > > > > > 10AC > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > > > > > > > > > > > > > > > > Hey Greg...I'll believe anything ..until I won't... Please > > fill > > > > us > > > > > in. > > > > > > > > > > > > We are hanging... > > > > > > > > > > > > On Wed, Sep 10, 2008 at 3:26 PM, Scott Forman > > > > > <scottforman75@>wrote: > > > > > > > > > > > > > You can't leave us hanging like that. > > > > > > > > > > > > > > Scott Forman > > > > > > > 86 PT38 > > > > > > > Memphis > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > "Gregory OConnor" > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > I tied ribbons in my grill last week and taped a piece > of > > > > erect > > > > > > > flat > > > > > > > > plastic pointed outward at drivers window and grill to > > get > > > a > > > > > clue on > > > > > > > > air flow. wont comment because you guys wont believe > it. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > > > > Curt Sprenger > > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > > Anaheim Hills, CA > > > > > > > > > > >I have followed with great interest the ribbon test > string??. I > > > too have constructed scoops to direct air into and through the > > > radiator in my '90 SP36. They stick out the sides 4 inches and > are > > > painted to match. Look pretty but were of little help. I did > not > > > use the ribbon test as I have a guage that measures inches of > water > > > in both directions. When I attached a long hose to it and > placed > > it > > > in various positions in the rear and side grills I found NO > > > measureable pressure. If anything the rear of the coach seems > to > > be > > > a calm area with very little air movement/pressure. I have yet > to > > > do the measure thing since the scoops were added. > > > Another thought worth considering is to install 12 volt cooling > > fans > > > on the side grills to suck air into and out through the > radiator. > > As > > > you can tell I am trying to limit the amount the fan runs. I > did > > > install a 180 deg. diverter (thermostat) in my 3208 but have not > > > taken it out with that change yet. Here's hoping! > > > Bob Criss > > > '90 SP36 > > > Bethel Park, PA > > > > > > > > > > |
