Another Saturday of Bird things
08-04-2007, 15:28
Ah yes, I reserved today for doing little projects on the Bird.
First, I wanted to find out why the throttle seems to hang up just a little above idle. I couldn't get it to hang up or bind while standing still. Next, I wanted to get the blowers from the inoperative dash AC to run just for air circulation. I can see on the schematic that there is a 30-amp breaker between the switches and the power source, but I couldn't locate it. There is no power to the switches. I suspect the breaker is above rather than down in the front. I did not want to take that apart today so I put this one on hold. I moved on to project number three, disconnect the speedometer cable from the cruise control so I could pull it up through the hole in the dash and reconnect the speedometer without reaching under the dash and risking shorting a few old wires. I had tried this several weeks ago but could not get the collar to loosen, I soaked it with WD-40 and today it broke loose. Success. Number 4; straighten the square aluminum extension on the bottom of the front strut of the large awning. One of the PO's must have brushed a tree or something bending the bar causing the struts to press tightly against the coach body when in a stored position. That is one tough piece of aluminum. My vice threatened to rip off the bench when I tried to bend the bar. I wound up sticking it into the receiver hitch on the bird and using a large pipe wrench and my foot. Another successful project. While I was doing these repairs I had the generator running for AC and to keep the Snapple cold in the icemaker (It was 95 around here today). I shut it down and went inside the house to take a shower and get the grease off. I came back out, all spiffy and clean, to take the bird back to the storage facility. I tried to start the generator, I tried to start the generator, and again, I tried to start the generator. Nothing! Then I noticed the automatic choke mechanism had fallen off the carburetor. I opened it up, reconnected it to the carb and reinstalled the spring, heater and hold-down screws. Still it wouldn't start. Then I saw that one of the spark plug leads had come out of the coil, so I put it back in, and it fired up and ran fine. So much for staying clean! So now, generator running, AC cooling, radio blasting, a cold Snapple by my side, I head for the storage facility. I notice that the throttle is sticking again, so I pull over and try to figure it out. I am beginning to suspect it is the transmission cable that is binding, but I wasn't able determine that for sure. I will examine it when things are a little cooler. Now I am finally at the storage facility. I pull the emergency breakaway cable out of the toad to set the brake, and proceed to disconnect safety chains and the Blue Ox tow bar. As usual, I have to rock the toad a little to get the pins out. But this time, after I pull the pin, the toad starts to roll slowly toward the bird, threatining to create a `Gardner ` sandwich. Seems like my $900 SMI braking system isn't doing its job! So I jump in the toad, return it to normal mode, and move it out of the way. I park the coach, store the tow bar in the storage compartment, and proceed to clean up and prepare the coach for storage. I lock up the coach and get in the toad, no keys! I wandered around in the dark searching the coach and the gravel lot over and over and over. Finally it dawns on me, maybe you had them in your hand when you put the tow bar away. Well, needless to say, I found them tangled in the safety cables under the tow bar in the storage compartment. So I managed to fix two things, put three things off, and loose my keys. I think I will take Sunday off. Gardner 78FC33 |
08-04-2007, 16:48
Were you alone on all of these projects, or was a Mister Murphy
"helping" you.? Jack Smith 1973FC31 Hot SoCal.. --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote: > > Ah yes, I reserved today for doing little projects on the Bird. > First, I wanted to find out why the throttle seems to hang up just a > little above idle. I couldn't get it to hang up or bind while > standing still. > > Next, I wanted to get the blowers from the inoperative dash AC > to run just for air circulation. I can see on the schematic that > there is a 30-amp breaker between the switches and the power source, > but I couldn't locate it. There is no power to the switches. > I suspect the breaker is above rather than down in the front. I did > not want to take that apart today so I put this one on hold. > > I moved on to project number three, disconnect the speedometer > cable from the cruise control so I could pull it up through the hole > in the dash and reconnect the speedometer without reaching under the > dash and risking shorting a few old wires. I had tried this several > weeks ago but could not get the collar to loosen, I soaked it with > WD-40 and today it broke loose. Success. > > Number 4; straighten the square aluminum extension on the bottom > of the front strut of the large awning. One of the PO's must have > brushed a tree or something bending the bar causing the struts to > press tightly against the coach body when in a stored position. That > is one tough piece of aluminum. My vice threatened to rip off the > bench when I tried to bend the bar. I wound up sticking it into the > receiver hitch on the bird and using a large pipe wrench and my > foot. Another successful project. > > While I was doing these repairs I had the generator running for AC > and to keep the Snapple cold in the icemaker (It was 95 around here > today). I shut it down and went inside the house to take a shower > and get the grease off. I came back out, all spiffy and clean, to > take the bird back to the storage facility. I tried to start the > generator, I tried to start the generator, and again, I tried to > start the generator. Nothing! Then I noticed the automatic choke > mechanism had fallen off the carburetor. I opened it up, reconnected > it to the carb and reinstalled the spring, heater and hold-down > screws. Still it wouldn't start. Then I saw that one of the spark > plug leads had come out of the coil, so I put it back in, and it > fired up and ran fine. So much for staying clean! > > So now, generator running, AC cooling, radio blasting, a cold > Snapple by my side, I head for the storage facility. I notice that > the throttle is sticking again, so I pull over and try to figure it > out. I am beginning to suspect it is the transmission cable that is > binding, but I wasn't able determine that for sure. I will examine > it when things are a little cooler. > > Now I am finally at the storage facility. I pull the emergency > breakaway cable out of the toad to set the brake, and proceed to > disconnect safety chains and the Blue Ox tow bar. As usual, I have > to rock the toad a little to get the pins out. But this time, after > I pull the pin, the toad starts to roll slowly toward the bird, > threatining to create a `Gardner ` sandwich. Seems like my $900 SMI > braking system isn't doing its job! > > So I jump in the toad, return it to normal mode, and move it out > of the way. I park the coach, store the tow bar in the storage > compartment, and proceed to clean up and prepare the coach for > storage. I lock up the coach and get in the toad, no keys! I > wandered around in the dark searching the coach and the gravel lot > over and over and over. Finally it dawns on me, maybe you had them > in your hand when you put the tow bar away. Well, needless to say, I > found them tangled in the safety cables under the tow bar in the > storage compartment. > > So I managed to fix two things, put three things off, and loose > my keys. I think I will take Sunday off. > > Gardner > 78FC33 > |
08-04-2007, 18:43
And U wanta take a trip to Alaska?? Should be very interesting.
MH ----- Original Message ----- From: Gardner Yeaw To: WanderlodgeForum@yahoogroups.com Sent: Saturday, August 04, 2007 9:28 PM Subject: [WanderlodgeForum] Another Saturday of Bird things Ah yes, I reserved today for doing little projects on the Bird. First, I wanted to find out why the throttle seems to hang up just a little above idle. I couldn't get it to hang up or bind while standing still. Next, I wanted to get the blowers from the inoperative dash AC to run just for air circulation. I can see on the schematic that there is a 30-amp breaker between the switches and the power source, but I couldn't locate it. There is no power to the switches. I suspect the breaker is above rather than down in the front. I did not want to take that apart today so I put this one on hold. I moved on to project number three, disconnect the speedometer cable from the cruise control so I could pull it up through the hole in the dash and reconnect the speedometer without reaching under the dash and risking shorting a few old wires. I had tried this several weeks ago but could not get the collar to loosen, I soaked it with WD-40 and today it broke loose. Success. Number 4; straighten the square aluminum extension on the bottom of the front strut of the large awning. One of the PO's must have brushed a tree or something bending the bar causing the struts to press tightly against the coach body when in a stored position. That is one tough piece of aluminum. My vice threatened to rip off the bench when I tried to bend the bar. I wound up sticking it into the receiver hitch on the bird and using a large pipe wrench and my foot. Another successful project. While I was doing these repairs I had the generator running for AC and to keep the Snapple cold in the icemaker (It was 95 around here today). I shut it down and went inside the house to take a shower and get the grease off. I came back out, all spiffy and clean, to take the bird back to the storage facility. I tried to start the generator, I tried to start the generator, and again, I tried to start the generator. Nothing! Then I noticed the automatic choke mechanism had fallen off the carburetor. I opened it up, reconnected it to the carb and reinstalled the spring, heater and hold-down screws. Still it wouldn't start. Then I saw that one of the spark plug leads had come out of the coil, so I put it back in, and it fired up and ran fine. So much for staying clean! So now, generator running, AC cooling, radio blasting, a cold Snapple by my side, I head for the storage facility. I notice that the throttle is sticking again, so I pull over and try to figure it out. I am beginning to suspect it is the transmission cable that is binding, but I wasn't able determine that for sure. I will examine it when things are a little cooler. Now I am finally at the storage facility. I pull the emergency breakaway cable out of the toad to set the brake, and proceed to disconnect safety chains and the Blue Ox tow bar. As usual, I have to rock the toad a little to get the pins out. But this time, after I pull the pin, the toad starts to roll slowly toward the bird, threatining to create a `Gardner ` sandwich. Seems like my $900 SMI braking system isn't doing its job! So I jump in the toad, return it to normal mode, and move it out of the way. I park the coach, store the tow bar in the storage compartment, and proceed to clean up and prepare the coach for storage. I lock up the coach and get in the toad, no keys! I wandered around in the dark searching the coach and the gravel lot over and over and over. Finally it dawns on me, maybe you had them in your hand when you put the tow bar away. Well, needless to say, I found them tangled in the safety cables under the tow bar in the storage compartment. So I managed to fix two things, put three things off, and loose my keys. I think I will take Sunday off. Gardner 78FC33 [Non-text portions of this message have been removed] |
08-05-2007, 05:45
Mike,
The possible Alaska trip (three years away)is the motivator to get everything up to snuff. I figure if I get my hands on every part of the Bird before leaving I will be able to handle most things that may come up during two or three months on the road. Anyway, the speedometer is working great now since I cleaned it up and gave the bearings a tiny puff of lube. It's about as accurate as the weather man, but it doesn't stick and jump anymore. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > And U wanta take a trip to Alaska?? Should be very interesting. > MH > ----- Original Message ----- > From: Gardner Yeaw > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, August 04, 2007 9:28 PM > Subject: [WanderlodgeForum] Another Saturday of Bird things > > > Ah yes, I reserved today for doing little projects on the Bird. > First, I wanted to find out why the throttle seems to hang up just a > little above idle. I couldn't get it to hang up or bind while > standing still. > > Next, I wanted to get the blowers from the inoperative dash AC > to run just for air circulation. I can see on the schematic that > there is a 30-amp breaker between the switches and the power source, > but I couldn't locate it. There is no power to the switches. > I suspect the breaker is above rather than down in the front. I did > not want to take that apart today so I put this one on hold. > > I moved on to project number three, disconnect the speedometer > cable from the cruise control so I could pull it up through the hole > in the dash and reconnect the speedometer without reaching under the > dash and risking shorting a few old wires. I had tried this several > weeks ago but could not get the collar to loosen, I soaked it with > WD-40 and today it broke loose. Success. > > Number 4; straighten the square aluminum extension on the bottom > of the front strut of the large awning. One of the PO's must have > brushed a tree or something bending the bar causing the struts to > press tightly against the coach body when in a stored position. That > is one tough piece of aluminum. My vice threatened to rip off the > bench when I tried to bend the bar. I wound up sticking it into the > receiver hitch on the bird and using a large pipe wrench and my > foot. Another successful project. > > While I was doing these repairs I had the generator running for AC > and to keep the Snapple cold in the icemaker (It was 95 around here > today). I shut it down and went inside the house to take a shower > and get the grease off. I came back out, all spiffy and clean, to > take the bird back to the storage facility. I tried to start the > generator, I tried to start the generator, and again, I tried to > start the generator. Nothing! Then I noticed the automatic choke > mechanism had fallen off the carburetor. I opened it up, reconnected > it to the carb and reinstalled the spring, heater and hold-down > screws. Still it wouldn't start. Then I saw that one of the spark > plug leads had come out of the coil, so I put it back in, and it > fired up and ran fine. So much for staying clean! > > So now, generator running, AC cooling, radio blasting, a cold > Snapple by my side, I head for the storage facility. I notice that > the throttle is sticking again, so I pull over and try to figure it > out. I am beginning to suspect it is the transmission cable that is > binding, but I wasn't able determine that for sure. I will examine > it when things are a little cooler. > > Now I am finally at the storage facility. I pull the emergency > breakaway cable out of the toad to set the brake, and proceed to > disconnect safety chains and the Blue Ox tow bar. As usual, I have > to rock the toad a little to get the pins out. But this time, after > I pull the pin, the toad starts to roll slowly toward the bird, > threatining to create a `Gardner ` sandwich. Seems like my $900 SMI > braking system isn't doing its job! > > So I jump in the toad, return it to normal mode, and move it out > of the way. I park the coach, store the tow bar in the storage > compartment, and proceed to clean up and prepare the coach for > storage. I lock up the coach and get in the toad, no keys! I > wandered around in the dark searching the coach and the gravel lot > over and over and over. Finally it dawns on me, maybe you had them > in your hand when you put the tow bar away. Well, needless to say, I > found them tangled in the safety cables under the tow bar in the > storage compartment. > > So I managed to fix two things, put three things off, and loose > my keys. I think I will take Sunday off. > > Gardner > 78FC33 > > > > > > [Non-text portions of this message have been removed] > |
08-05-2007, 13:25
that's the spirit.
MH ----- Original Message ----- From: Gardner Yeaw To: WanderlodgeForum@yahoogroups.com Sent: Sunday, August 05, 2007 11:45 AM Subject: [WanderlodgeForum] Re: Another Saturday of Bird things Mike, The possible Alaska trip (three years away)is the motivator to get everything up to snuff. I figure if I get my hands on every part of the Bird before leaving I will be able to handle most things that may come up during two or three months on the road. Anyway, the speedometer is working great now since I cleaned it up and gave the bearings a tiny puff of lube. It's about as accurate as the weather man, but it doesn't stick and jump anymore. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > And U wanta take a trip to Alaska?? Should be very interesting. > MH > ----- Original Message ----- > From: Gardner Yeaw > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, August 04, 2007 9:28 PM > Subject: [WanderlodgeForum] Another Saturday of Bird things > > > Ah yes, I reserved today for doing little projects on the Bird. > First, I wanted to find out why the throttle seems to hang up just a > little above idle. I couldn't get it to hang up or bind while > standing still. > > Next, I wanted to get the blowers from the inoperative dash AC > to run just for air circulation. I can see on the schematic that > there is a 30-amp breaker between the switches and the power source, > but I couldn't locate it. There is no power to the switches. > I suspect the breaker is above rather than down in the front. I did > not want to take that apart today so I put this one on hold. > > I moved on to project number three, disconnect the speedometer > cable from the cruise control so I could pull it up through the hole > in the dash and reconnect the speedometer without reaching under the > dash and risking shorting a few old wires. I had tried this several > weeks ago but could not get the collar to loosen, I soaked it with > WD-40 and today it broke loose. Success. > > Number 4; straighten the square aluminum extension on the bottom > of the front strut of the large awning. One of the PO's must have > brushed a tree or something bending the bar causing the struts to > press tightly against the coach body when in a stored position. That > is one tough piece of aluminum. My vice threatened to rip off the > bench when I tried to bend the bar. I wound up sticking it into the > receiver hitch on the bird and using a large pipe wrench and my > foot. Another successful project. > > While I was doing these repairs I had the generator running for AC > and to keep the Snapple cold in the icemaker (It was 95 around here > today). I shut it down and went inside the house to take a shower > and get the grease off. I came back out, all spiffy and clean, to > take the bird back to the storage facility. I tried to start the > generator, I tried to start the generator, and again, I tried to > start the generator. Nothing! Then I noticed the automatic choke > mechanism had fallen off the carburetor. I opened it up, reconnected > it to the carb and reinstalled the spring, heater and hold-down > screws. Still it wouldn't start. Then I saw that one of the spark > plug leads had come out of the coil, so I put it back in, and it > fired up and ran fine. So much for staying clean! > > So now, generator running, AC cooling, radio blasting, a cold > Snapple by my side, I head for the storage facility. I notice that > the throttle is sticking again, so I pull over and try to figure it > out. I am beginning to suspect it is the transmission cable that is > binding, but I wasn't able determine that for sure. I will examine > it when things are a little cooler. > > Now I am finally at the storage facility. I pull the emergency > breakaway cable out of the toad to set the brake, and proceed to > disconnect safety chains and the Blue Ox tow bar. As usual, I have > to rock the toad a little to get the pins out. But this time, after > I pull the pin, the toad starts to roll slowly toward the bird, > threatining to create a `Gardner ` sandwich. Seems like my $900 SMI > braking system isn't doing its job! > > So I jump in the toad, return it to normal mode, and move it out > of the way. I park the coach, store the tow bar in the storage > compartment, and proceed to clean up and prepare the coach for > storage. I lock up the coach and get in the toad, no keys! I > wandered around in the dark searching the coach and the gravel lot > over and over and over. Finally it dawns on me, maybe you had them > in your hand when you put the tow bar away. Well, needless to say, I > found them tangled in the safety cables under the tow bar in the > storage compartment. > > So I managed to fix two things, put three things off, and loose > my keys. I think I will take Sunday off. > > Gardner > 78FC33 > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
