Black Streaks
07-22-2007, 09:03
Black Streaks
Leroy- were the new screws that you installed for the diamond plate?
Ernie Ekberg 83PT40 Livingston, Mt ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] |
07-22-2007, 10:12
Black Streaks
Ah- I see now. When you get a chance, between your waxings- mine is in kinda
need of~ Ernie Ekberg 83PT40 Livingston, Mt ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] |
07-22-2007, 12:13
Black Streaks
I waited one year to post the results of my idea just to be certain it worked.
My coach lives outside in Florida. Although it resides 30 miles from the beach things can get nasty. I concluded that steel self tapping screws used by BB in the manufacture of the coach were the major problem. Even though the heads were painted, over time the paint cracks at the base of the screw and allows water to be introduced. If not addressed, bad things can occur resulting in streaks and body deteriation. I embarked upon a mission to replace all exterior screws with stainless sheet metal screws. Most of the screws were #10 one inch long. I purchased them from ACE.There were some that were 11/2" long screws and a few were 2". One at a time I removed them, used clear silicone to seal the hole and installed the new screws. I can say today that 90 percent of the streaking is gone. I did not paint the heads of the screws, I left the detail similar to hardware used by aircraft owners on cowling and inspection panels. My coach is Indian Silver primary and Cumulous Grey secondary so it looks very nice. Others may think differently. I am considering replacing the pop rivets that surround the bay doors with stainless hardware to include aircraft grade Tinnerman washers and countersunk screws. Tinnerman washers allow for movement where pop rivets do not. At this moment I do not have a problem in this area. Just wanted to share this with the folks restoring their coaches. Stainless fasteners are not much more expensive than other products. I have used stainless screws on aircraft I have owned for 30 years without any problem. Just finished my custom installation of the PTMS from Stephen this weekend. It was hot, really hot. Regards; Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Royale Conversion [Non-text portions of this message have been removed] |
07-22-2007, 14:02
Black Streaks
Ernie, I do not have diamond plate on the roof. I assume that is what you are
speaking of . True to form on my coach I have another type of aluminum rib plate on the roof. It is about 1/2"x1/2" rib flat work, probably stamped or rolled because it is to large to have been extruded. I do not have any leaks so I have left it alone. What I did was replace the screws(vertical attachments,side walls all around) that attach awnings, trim pieces, door trim, anything I could find that was attached by self drilling steel screws. That goes for light attachment screws, chrome or anodized trim screws, and drip rail attachment screws. So far so good. I now have to wax the coach twice a year now and the majority of black streaks have gone South. Thank God. Leroy Eckert 1990WB-40"Smoke N Mirrors" Niceville, FL Royale Conversion ----- Original Message ----- From: erniecarpet@... To: WanderlodgeForum@yahoogroups.com Sent: Sunday, July 22, 2007 8:03 PM Subject: Re: [WanderlodgeForum] Black Streaks Leroy- were the new screws that you installed for the diamond plate? Ernie Ekberg 83PT40 Livingston, Mt ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
07-22-2007, 14:42
Black Streaks
Well, I can do it, but I don't wanna unless you buy the beer. It is to hot
now.lol. Serious, replace those screws with stainless, it will make your life easier in the long term. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Rolyale Conversion ----- Original Message ----- From: erniecarpet@... To: WanderlodgeForum@yahoogroups.com Sent: Sunday, July 22, 2007 9:12 PM Subject: Re: [WanderlodgeForum] Black Streaks Ah- I see now. When you get a chance, between your waxings- mine is in kinda need of~ Ernie Ekberg 83PT40 Livingston, Mt ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
07-22-2007, 17:30
Black Streaks
From: Leroy Eckert To: WanderlodgeForum@yahoogroups.com Sent: Sunday, July 22, 2007 7:13 PM Subject: [WanderlodgeForum] Black Streaks Leroy I to replace all the screws in my bird with stainless screws. I have look at the pictures of Leroy birds boy how I love the look of all the stainless .Good job Leroy. Bob Loomas 1985 PT 36 I waited one year to post the results of my idea just to be certain it worked. My coach lives outside in Florida. Although it resides 30 miles from the beach things can get nasty. I concluded that steel self tapping screws used by BB in the manufacture of the coach were the major problem. Even though the heads were painted, over time the paint cracks at the base of the screw and allows water to be introduced. If not addressed, bad things can occur resulting in streaks and body deteriation. I embarked upon a mission to replace all exterior screws with stainless sheet metal screws. Most of the screws were #10 one inch long. I purchased them from ACE.There were some that were 11/2" long screws and a few were 2". One at a time I removed them, used clear silicone to seal the hole and installed the new screws. I can say today that 90 percent of the streaking is gone. I did not paint the heads of the screws, I left the detail similar to hardware used by aircraft owners on cowling and inspection panels. My coach is Indian Silver primary and Cumulous Grey secondary so it looks very nice. Others may think differently. I am considering replacing the pop rivets that surround the bay doors with stainless hardware to include aircraft grade Tinnerman washers and countersunk screws. Tinnerman washers allow for movement where pop rivets do not. At this moment I do not have a problem in this area. Just wanted to share this with the folks restoring their coaches. Stainless fasteners are not much more expensive than other products. I have used stainless screws on aircraft I have owned for 30 years without any problem. Just finished my custom installation of the PTMS from Stephen this weekend. It was hot, really hot. Regards; Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Royale Conversion [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
07-23-2007, 08:41
Black Streaks
Thank you. It was a job I will never do again.lol As for the screws, I expect
you saw quite a difference also. Leroy Eckert 1990WB-40"Smoke N Mirrors" Niceville, FL Royale Conversion ----- Original Message ----- From: bloomas To: WanderlodgeForum@yahoogroups.com Sent: Monday, July 23, 2007 12:30 AM Subject: Re: [WanderlodgeForum] Black Streaks ----- Original Message ----- From: Leroy Eckert To: WanderlodgeForum@yahoogroups.com Sent: Sunday, July 22, 2007 7:13 PM Subject: [WanderlodgeForum] Black Streaks Leroy I to replace all the screws in my bird with stainless screws. I have look at the pictures of Leroy birds boy how I love the look of all the stainless .Good job Leroy. Bob Loomas 1985 PT 36 I waited one year to post the results of my idea just to be certain it worked. My coach lives outside in Florida. Although it resides 30 miles from the beach things can get nasty. I concluded that steel self tapping screws used by BB in the manufacture of the coach were the major problem. Even though the heads were painted, over time the paint cracks at the base of the screw and allows water to be introduced. If not addressed, bad things can occur resulting in streaks and body deteriation. I embarked upon a mission to replace all exterior screws with stainless sheet metal screws. Most of the screws were #10 one inch long. I purchased them from ACE.There were some that were 11/2" long screws and a few were 2". One at a time I removed them, used clear silicone to seal the hole and installed the new screws. I can say today that 90 percent of the streaking is gone. I did not paint the heads of the screws, I left the detail similar to hardware used by aircraft owners on cowling and inspection panels. My coach is Indian Silver primary and Cumulous Grey secondary so it looks very nice. Others may think differently. I am considering replacing the pop rivets that surround the bay doors with stainless hardware to include aircraft grade Tinnerman washers and countersunk screws. Tinnerman washers allow for movement where pop rivets do not. At this moment I do not have a problem in this area. Just wanted to share this with the folks restoring their coaches. Stainless fasteners are not much more expensive than other products. I have used stainless screws on aircraft I have owned for 30 years without any problem. Just finished my custom installation of the PTMS from Stephen this weekend. It was hot, really hot. Regards; Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Royale Conversion [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
07-23-2007, 14:20
Black Streaks
Stainless works fine for most exterior finishing but watch out when you use them
where stress or flexing comes into play. I used a high grade self tapping stainless on my ladder and 3 out of 4 broke in one short trip around the block. I was able to remove 2 of the screws with vise grips but the 3rd would NOT come out. I bought special drill bits and nothing would touch it so i had to punch it through from the outside and finished the job by installing bolts from the inside and used a nice acorn nut on the outside. " Had to remove the shelf at the window ledge from the inside" Anyway, the old 77 FC is looking better by the bolt! jim --------------------------------- Get the Yahoo! toolbar and be alerted to new email wherever you're surfing. [Non-text portions of this message have been removed] |
07-23-2007, 14:54
Black Streaks
From: james sears To: WanderlodgeForum@yahoogroups.com Sent: Monday, July 23, 2007 9:20 PM Subject: [WanderlodgeForum] Re: Black Streaks Hay James glad your bird is coming along.ok Hold down the fort in Harahan La Bob Loomas 1985 PT 36 @ Grand Forks AFB Stainless works fine for most exterior finishing but watch out when you use them where stress or flexing comes into play. I used a high grade self tapping stainless on my ladder and 3 out of 4 broke in one short trip around the block. I was able to remove 2 of the screws with vise grips but the 3rd would NOT come out. I bought special drill bits and nothing would touch it so I had to punch it through from the outside and finished the job by installing bolts from the inside and used a nice acorn nut on the outside. " Had to remove the shelf at the window ledge from the inside" Anyway, the old 77 FC is looking better by the bolt! jim --------------------------------- Get the Yahoo! toolbar and be alerted to new email wherever you're surfing. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
