Perkins fuel injector pump.
06-12-2007, 12:28
A while ago I posted that mine was leaking. The engine starts, runs,
and leaks. I went to a mechanic today and he said there is an inspection port that has allignment marks on it and that if these are aligned with a mark on the housing, I should be able to remove that pump and take it to a rebuild shop. Question: Has any of you done this? I can take anything apart, but if it has to have timing marks alligned- what can I expect or look for?? Thanks to all for this. Ernie-83PT40 in Montana- why should this leak-- only has 6500 hours on the clock??? |
06-12-2007, 20:31
Thank you very much, John. I did not realize that was an Allen head bolt in
the back of the pump. I , too, have lots of paint on the pump. Can you forward some cash for the rebuild?? VBG!! Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
06-13-2007, 00:26
Good Morning Ernie,
I'm not sure what inspection port that the mechanic is talking about, but I just recently removed and replaced the injector pump on my Perkins and here are a couple of photo tips for you, the first one will show you where those timing marks are located, believe me they are very hard to see, check out; http://www.pbase.com/iamflagman/image/80456505 The second photo tip will show you what it takes to remove the backside bolt on the injector pump; http://www.pbase.com/iamflagman/image/80456508 Be sure to follow the instructions on the injector pump removal found in the Perkins Workshop Manual under SECTION N. I will expect this repair to be completed on your injector pump and ready for my inspection when I arrive up there next month :o) JOHN FINN 1982 FC35RB BLUEBIRD WANDERLODGE HOPKINS, SOUTH CAROLINA VISIT THE FINN'S INN EXPRESS REMODELING ADVENTURE AND TECH. TIPS http://www.pbase.com/image/24977457 /////////////////////////////////////////////////////// --- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > A while ago I posted that mine was leaking. The engine starts, runs, > and leaks. I went to a mechanic today and he said there is an > inspection port that has allignment marks on it and that if these are > aligned with a mark on the housing, I should be able to remove that > pump and take it to a rebuild shop. Question: Has any of you done this? > I can take anything apart, but if it has to have timing marks alligned- > what can I expect or look for?? > Thanks to all for this. > Ernie-83PT40 in Montana- why should this leak-- only has 6500 hours on > the clock??? > |
06-13-2007, 01:38
Ernie,
You might want to go to the Links section and look at the Perkins Engine Repair Manual that is available online. It is a very big help. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > A while ago I posted that mine was leaking. The engine starts, runs, > and leaks. I went to a mechanic today and he said there is an > inspection port that has allignment marks on it and that if these are > aligned with a mark on the housing, I should be able to remove that > pump and take it to a rebuild shop. Question: Has any of you done this? > I can take anything apart, but if it has to have timing marks alligned- > what can I expect or look for?? > Thanks to all for this. > Ernie-83PT40 in Montana- why should this leak-- only has 6500 hours on > the clock??? > |
06-13-2007, 05:36
Thanks, Mike, will do.
