					Added external propane quick connector
					06-10-2007, 15:55
				 Post: #11 | |||
					----- Original Message ----- From: bluebird3208 To: WanderlodgeForum@yahoogroups.com Sent: Sunday, June 10, 2007 9:08 PM Subject: [WanderlodgeForum] Re: Added external propane quick connector Jim Thank you Bob Loomas 1985 PT 36 --- In WanderlodgeForum@yahoogroups.com, "bloomas" wrote:That would be Carbon monoxide. Jim > > > ----- Original Message ----- > From: davidkerryedwards > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, June 10, 2007 6:10 PM > Subject: [WanderlodgeForum] Added external propane quick connector > Yes and you can also kill you and your family from carbodioxide if the bird is not properly ventilated.It is > your bird do with it you want. > Bob Loomas 1985 PT 36 > > > Added a quick connect fitting to the propane tank today so I can hook up outside campstove. > Took the elbow going into the regulator and replaced it with a T, put a second regulator > above the existing one with a quick connect hose fitting. Took about an hour and about $20 > in parts. I can also plug in a small propane heater, running the hose in thru a window so > when dry camping I can get propane heat without the need for electricity if necessary. > > Kerry > 82 Fc 35 > Denver > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] | |||
 Member Funded
Member Funded Link Directory
User Locations Gallery
Gallery Calendar
