					Solution to T handle location for HWH jacks
					06-05-2007, 07:37
				 Post: #1 | |||
					Paul thank you for sharing all this information. Glad you weren't stuck on the tracks, also. Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] | |||
					06-05-2007, 11:05
				 Post: #2 | |||
					I cannot attest that all model BBs will have the solenoid manifold with the T handles located in the same place, but am pretty sure that all WB, LX and LXi models should have them in the same place. If your manifold is located in front of the steps and up higher, then this solution "should" work for you. Make sure you retract the jacks first! There is plenty of slack in all the cables and hoses, so all you have to do is remove the manifold, file or grind the cutout open a bit more, and just turn it 180 degrees. This will put the T handles within easy reach once you move your generator out on it's slides. The handles will be easily accessible if you just reach behind the headlight. You will find it much easier to do if you remove the hoses (neater if you plug the hoses while working on them). The system is no under pressure when the jacks are retracted and is self priming. There will be only a few drops of fluid lost. Make sure you get the hoses on the correct solenoid after turning. the two outside solenoids are LR & RR and the center solenoids are LF & RF. Test the system when you think you are finished. The right side jacks should deploy first (both front and back) then the left side. Feel free to contact me if you have any questions. Paul 97wb43 | |||
 Member Funded
Member Funded Link Directory
User Locations Gallery
Gallery Calendar
