m380 cummins
05-28-2007, 05:56
m380 cummins
we were driving up 95 n of richmond when i was telling my wife how
enjoyable this m380 has been when i started to lose power, turbo
booster went to 0 and with foot to the floor with no power i was able
to get to the side of this 4 lane packed highway as the engine cut off
and had to steer with no assist barely out of harmes way. Initially the
engine would not start, but after a 30 min wait it did. i decide to
try driving along the side slowly, turbo was registering and everything
seemed fine all gauges normal,so out on 95 we went with no more problem.
during that 30 min i talked to my local rv guy who thought it was an
electrical problem, jessie at bb was going to look up some master prob
list, havn't heard back. any thoughts on what may have occured. i have
synthetic fluds in the tranny as well as the engine, and all guages
have stayed remakably normal.
jim
05-28-2007, 08:40
m380 cummins
Sounds like a grounding problem. Check the grounds from the batteries
and engine to the frame. Make sure they're tight and free of corrosion.
Pete Masterson
aeonix1@...
On the road at Lockhart Texas
> the
> everything
> problem.
> have
> jim
05-28-2007, 12:48
m380 cummins
I agree with Pete. Start with the grounds. You did not mention if you had any
warning lights. It may not hurt to run a check on the electronic controls
through the DDL just to see if anything is there.
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Sent: Monday, May 28, 2007 3:40 PM
Subject: Re: [WanderlodgeForum] m380 cummins
Pete Masterson
aeonix1@...
> the
> everything
> problem.
> have
> jim
05-28-2007, 12:54
m380 cummins
The computer will hold the answer. I have a N14 and a M11 In trucks
and they keep codes forever. $65.00 to have it read by a tech that
can evaluate the clues the codes reveal.
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, "brystal9" <bbtravel@...>
able
off
to
everything
problem.
an
prob
have
> jim
