					84FC35 ride height
					05-03-2007, 03:52
				 Post: #1 | |||
| 84FC35 ride height
					How difficult is it to adjust the ride height on my 84FC?  What is the proper ride height and where do I measure from? Should I have someone do this for me? Keith 84FC35 | |||
					05-03-2007, 04:05
				 Post: #2 | |||
| 84FC35 ride height
					Keith: There should be a blue folder in your blue box for the ridewell air suspension system. It will direct you on how to set the ride height and you can do it yourself. It is time consuming though and best to make small adjustments, run the coach around the block then measure, then adjust and go around the block and so forth. The front will be aprox 1 inch lower in the front and that is normal. Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma At 03:52 PM 5/3/2007 +0000, you wrote: >How difficult is it to adjust the ride height on my 84FC? What is the >proper ride height and where do I measure from? > >Should I have someone do this for me? > >Keith >84FC35 > > > | |||
					05-03-2007, 05:49
				 Post: #3 | |||
| 84FC35 ride height
					Thanks Ralph, I'll check it out... Keith 84FC --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Keith: > > There should be a blue folder in your blue box for the ridewell air > suspension system. It will direct you on how to set the ride height and you > can do it yourself. It is time consuming though and best to make small > adjustments, run the coach around the block then measure, then adjust and > go around the block and so forth. The front will be aprox 1 inch lower in > the front and that is normal. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Ralph's RV Solutions, Duncan, Oklahoma > > At 03:52 PM 5/3/2007 +0000, you wrote: > >How difficult is it to adjust the ride height on my 84FC? What is the > >proper ride height and where do I measure from? > > > >Should I have someone do this for me? > > > >Keith > >84FC35 > > > > > > > | |||
 Member Funded
Member Funded Link Directory
User Locations Gallery
Gallery Calendar
