					Aquahot PM and start/stop of new pump
					05-02-2007, 01:10
				 Post: #1 | |||
					Good morning everyone: Earlier this year I had an Aquahot hot water problem on a '95 Bird. Low flow was the symptom. I shut off the incoming cold water source, drained the hot water side and took the hot water input and output fittings apart. Then using an old Par pump, I pumped in 1 gallon of vinegar until it started to flow out of the output side then shut the out put valve off while still pumping and let the Par pump shut off at it's 40 psi point, un plugged the Par pump and walked away form about 5 hours leaving the vinegar to sit static. Returning to the Aquahot after 5 hours, I put the output hose into a container, ran a cold water source to the input side and started the pump and opening the valves. The solution coming out was blue/green in color. I completely flushed the system with fresh water until the color of the water was clear. Then hooked the lines back up and started the water running in the coach. No more lack of flow problem. This procedure should be added to the yearly PM schedule. The Aquahot hot water is an heat on demand system and the 3/8 copper tubing wrapped around the heat source will scale and start to plug the anti scald valve. This may also have something to do with a present problem with the 5.7gpm 65 psi pump run/stop/run/stop. I noticed this happening on the one I installed in my coach and I found that I had a slight blockage on the out put side. When I found that problem and repaired it, I had no more problem. Just some thoughts on that. Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma | |||
					05-02-2007, 01:27
				 Post: #2 | |||
					Thanks for the tip Ralph, I'll definitely look into it. David Brady '02 LXi, Smokey NC Ralph L. Fullenwider wrote: > > Good morning everyone: > > Earlier this year I had an Aquahot hot water problem on a '95 Bird. Low > flow was the symptom. I shut off the incoming cold water source, drained > the hot water side and took the hot water input and output fittings > apart. > Then using an old Par pump, I pumped in 1 gallon of vinegar until it > started to flow out of the output side then shut the out put valve off > while still pumping and let the Par pump shut off at it's 40 psi > point, un > plugged the Par pump and walked away form about 5 hours leaving the > vinegar > to sit static. > > Returning to the Aquahot after 5 hours, I put the output hose into a > container, ran a cold water source to the input side and started the pump > and opening the valves. The solution coming out was blue/green in > color. I > completely flushed the system with fresh water until the color of the > water > was clear. Then hooked the lines back up and started the water running in > the coach. No more lack of flow problem. > > This procedure should be added to the yearly PM schedule. The Aquahot hot > water is an heat on demand system and the 3/8 copper tubing wrapped > around > the heat source will scale and start to plug the anti scald valve. > > This may also have something to do with a present problem with the 5.7gpm > 65 psi pump run/stop/run/stop. I noticed this happening on the one I > installed in my coach and I found that I had a slight blockage on the out > put side. When I found that problem and repaired it, I had no more > problem. > Just some thoughts on that. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Ralph's RV Solutions, Duncan, Oklahoma > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.467 / Virus Database: 269.6.2/784 - Release Date: 5/1/2007 2:57 PM > [Non-text portions of this message have been removed] | |||
					05-02-2007, 02:15
				 Post: #3 | |||
					Where is my creditr line for vinigar  idea:  "Ralph L. Fullenwider" Earlier this year I had an Aquahot hot water problem on a '95 Bird. Low flow was the symptom. I shut off the incoming cold water source, drained the hot water side and took the hot water input and output fittings apart. Then using an old Par pump, I pumped in 1 gallon of vinegar until it started to flow out of the output side then shut the out put valve off while still pumping and let the Par pump shut off at it's 40 psi point, un plugged the Par pump and walked away form about 5 hours leaving the vinegar to sit static. Returning to the Aquahot after 5 hours, I put the output hose into a container, ran a cold water source to the input side and started the pump and opening the valves. The solution coming out was blue/green in color. I completely flushed the system with fresh water until the color of the water was clear. Then hooked the lines back up and started the water running in the coach. No more lack of flow problem. This procedure should be added to the yearly PM schedule. The Aquahot hot water is an heat on demand system and the 3/8 copper tubing wrapped around the heat source will scale and start to plug the anti scald valve. This may also have something to do with a present problem with the 5.7gpm 65 psi pump run/stop/run/stop. I noticed this happening on the one I installed in my coach and I found that I had a slight blockage on the out put side. When I found that problem and repaired it, I had no more problem. Just some thoughts on that. Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma Yahoo! Groups Links Wallace Craig 95 WLWB 42 Azle, Texas [Non-text portions of this message have been removed] | |||
					05-02-2007, 02:29
				 Post: #4 | |||
					Good morning Wallace: That is true, you did have that idea to begin with and the Factory Aquahot Reps backed it up. And it worked, even though I was reluctant at first. Of course, I was also reluctant to "sour" Now, had we added salad oil to the vinegar, it would have made for nice lunch. The color may have been a little off and clash with the tomatoes though. VBS Ralph At 07:15 AM 5/2/2007 -0700, you wrote: >Where is my creditr line for vinigar idea: > >"Ralph L. Fullenwider" > >Earlier this year I had an Aquahot hot water problem on a '95 Bird. Low >flow was the symptom. I shut off the incoming cold water source, drained >the hot water side and took the hot water input and output fittings apart. >Then using an old Par pump, I pumped in 1 gallon of vinegar until it >started to flow out of the output side then shut the out put valve off >while still pumping and let the Par pump shut off at it's 40 psi point, un >plugged the Par pump and walked away form about 5 hours leaving the vinegar >to sit static. > >Returning to the Aquahot after 5 hours, I put the output hose into a >container, ran a cold water source to the input side and started the pump >and opening the valves. The solution coming out was blue/green in color. I >completely flushed the system with fresh water until the color of the water >was clear. Then hooked the lines back up and started the water running in >the coach. No more lack of flow problem. > >This procedure should be added to the yearly PM schedule. The Aquahot hot >water is an heat on demand system and the 3/8 copper tubing wrapped around >the heat source will scale and start to plug the anti scald valve. > >This may also have something to do with a present problem with the 5.7gpm >65 psi pump run/stop/run/stop. I noticed this happening on the one I >installed in my coach and I found that I had a slight blockage on the out >put side. When I found that problem and repaired it, I had no more problem. >Just some thoughts on that. > >Safe travels, > >Ralph and Charolette Fullenwider >84FC35 >Ralph's RV Solutions, Duncan, Oklahoma > > > > >Yahoo! Groups Links > > > > > > >Wallace Craig > 95 WLWB 42 > Azle, Texas > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma | |||
 Member Funded
Member Funded Link Directory
User Locations Gallery
Gallery Calendar
